-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Unlimited04's LJ Build (http://www.jeepforum.com/forum/f9/unlimited04s-lj-build-778715/)
Unlimited04 05-16-2009 05:35 PM
I try to keep this updated with tech regarding my Jeep. Direct links are imbedded in this first post, and many others. Check the links, read, learn and ask questions
My goal is a fairly capable general purpose Jeep. It sees general utility usage, crowded city parking garages, long highway drives, lots of snow and ice conditions and scenic mountain 4x4 trails in Colorado. It's not a rock crawler...its more of a general purpose expedition Jeep and its going to go be a jack of all trades, master of none.
Index:
The beginning:
My comprehensive 33" tire build:
Mods for 33" tires
Additional Completed Mods:
Still in process:
Off-Road Utility/Camping Trailer Build
Wish List:
  • NV3550 manual trans
  • highline fenders
  • dual rate front sway bar
You don't NEED all this to run 33s, but above is what I would consider a comprehensive 2.5" lift kit to bring all steering, suspension and driveline geometry to where they should be, while still providing an exceptional daily driver and capable off road rig.
Removed mods:
JKS front track bar
Reason: didn't work.
JKS rear track bar
Riddler Diff covers
Reason: major clearance problems, front track bar & gas tank skid interference.
Homemade 23mm bumpstops
Reason: Removed from front. Welded on 3/8" plate & tapped spring pad for bumpstops. Used in the rear to make 1.3" bumpstop extension.
Homemade t-case drop (6061-T611 aluminum)
Reason: installed SYE/CV shaft.
Zone Off-Road front cam bolts
Reason: installed Rokmen control arms. Caster now at 6.2 with HP D30 swap.
Daystar 0.75" spacers for front & OME 933 front springs
Reason: went with 934 front springs after installing winch.
Homemade Tire Carrier
Reason: weight reduction & trade for Unichip Q (for hi-perf engine mods to come)
Kilby Gas tank skid
Reason: weight reduction - went to Savvy gas tank skid.
2 Explorer fans and 2 "Severe Duty" fan clutches
Reason: Overheating issues while idling, belt squealing at higher RPMs, didn't work as good as stock. More info here in this Explorer fan thread.
Explorer 46mm calipers from Vanco kit
Reason: Upgraded to Explorer Sport Trac 48mm calipers with Black Magic Brake pads and Centric rotors thanks to mrblaine (www.blackmagicbrakes.com)
Currie 1" MML
Reason: Chasing driveline vibes. Replaced with Brown Dog rubber w/ super block brackets. Did not notice a difference in vibes between the two.
JeepMedic engine skid & tummy tuck
Reason: Weight loss program - went to Savvy UnderArmor tummy tuck and engine skid. But the JeepMedic is still a great design.
Rear TrueTrac
Reason: Jeep no longer a daily driver in snow, so went to ARB.
Front TrueTrac
Suggested Readings
General:
Suspension/Steering:
Engine:
Drivetrain:
Brakes:
Other Build Threads:
Unlimited04 05-16-2009 05:46 PM
Pictures!
Before Lift:
http://i133.photobucket.com/albums/q...l/DSC01405.jpg
After Lift:
http://i133.photobucket.com/albums/q...l/DSC01422.jpg
Front suspension:
http://i133.photobucket.com/albums/q...l/DSC01427.jpg
*See more info here: http://www.jeepforum.com/forum/f9/un...l#post11060714
*NOTE: This JKS track bar hit the Riddler diff cover big time...both have since been replaced
http://i133.photobucket.com/albums/q...l/DSC01428.jpg
*this combination proved to have major clearance issues, resulting in 1.5" less uptravel than stock*
Read here:
http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
JKS Quicker Discos:
http://i133.photobucket.com/albums/q...l/DSC01426.jpg
*Bumpstops have since changed, see here: http://www.jeepforum.com/forum/f9/un...l#post11060714
Ground clearance:
Before:
http://i133.photobucket.com/albums/q...p/DSC01385.jpg
After:
http://i133.photobucket.com/albums/q...l/DSC01423.jpg
Rear Driveline Angle:
http://i133.photobucket.com/albums/q...l/DSC01430.jpg
The biggest problem encountered during the lift install is the passenger side rear shock mount: http://www.jeepforum.com/forum/f9/lift-install-problems-778320/
http://i133.photobucket.com/albums/q...l/DSC01424.jpg
I used a 1/16" HSS steel bitt to drill a pilot hole, then followed it with a Cobalt steel drill bit completely drill the bolts out. Tried to chip the weld-nut off with a tool steel chisel, it sure busted up the nut, but isn't doing much to the weld. The weld must be fairly high tensile strength stuff.
Unlimited04 05-16-2009 05:58 PM
I can't comment on the ride yet because there is no right rear shock and i'm bouncing all over the freakin' place. I can't go over about 40-45mph because it bounces like crazy. Can't comment on vibes yet either because I can't drive highway yet, and when I am driving, I'm bouncing....
But here's somes measurements of the gains:
Before-
Drivers Rear: 33.25"
Pass Rear: 33.25"
Drivers Front: 33.5"
Pass Front: 32.75"
To the Tummy Tuck: 11.125"
Lowest point on the front control arm frame side bracket: 9.25"
Front Bumper: 17.875"
Rear Bumper: 15"
After-
Drivers Rear: 37.25"
Pass Rear: 36.875"
Drivers Front: 36.625"
Pass Front: 36.5"
To the Tummy Tuck: 14.875"
Lowest point on the front control arm frame side bracket: 12.75"
Front Bumper: 21.25"
Rear Bumper: 18.75"
Hopefully it settles a little bit, because its actually about 1" taller than I'd like. It also sits slightly nose high, or level, because of the 0.75" spacer up front, and the fact that I don't have my engine skid on. I'd hoped this nose-high would point the output shaft down a bit more and prevent me from having to install a SYE/CV or t-case drop.
Track bars still need some work. Rear axle is too far left and the front axle is slightly pushed right. Maybe off 3/8" in rear and 1/8" in front. I also put blue Locktite on the track bar, so it should be fun to loosen. Another project for tomorrow after I get the rear shock on.
As I had hoped, the ground clearance with the JeepMedic tummy tuck + 2.5" OME lift is freaking awesome. I can have a party under there :hahaha: I honestly don't know why you would need more than this for a DD.
rubidriver 05-16-2009 05:59 PM
You finally did it. I see you did go with the JKS track bar. It looks like you wont be having any trouble with it hitting, although you might need more bumpstop in the front. You are running a hair shy of suggested bumpstop for 33's on those springs.
Unlimited04 05-16-2009 06:25 PM
EDIT: Answered here - front bumpstops
rubidriver 05-16-2009 06:29 PM
Originally Posted by Unlimited04 (Post 7234166)
what bumpstop should I have in front? The ones in there now are 23mm, which is 0.905".
With the 933 in the front normally you do a 2". With your BL you may not need that extra tho. You will be able to find out when you get your new tires ofcourse.
Unlimited04 05-16-2009 06:46 PM
In case anyone's interested, here is the laser alignment data from the shop. The uncorrected toe-in and drag-link made for some white-knuckle 30mph driving, thats for sure.
Camber (L/R):
Before: -0.8/-0.8
After: -0.8/-0.7
Caster (L/R):
Before: 4.2/4.5
After: 4.2/4.5
Toe (L/R):
Before: 0.68/0.59
After: 0.15/0.14
EDIT: After dialing the suspension in over many iterations, as described in this thread, I've got a comment about caster & drive-ability.
Originally Posted by Unlimited04 (Post 14488717)
the road crown around here sucks and at 5 it followed every defect, return to center blew, and the steering felt very dartish with little resistance and no tendency to want to go straight with no hands on the wheel/little input. I also had a harmonic steering vibration feedback (not DW) at certain speeds, which could yield DW if hitting a big enough bump. As I dialed the caster up in 0.5 increments (with corresponding toe adjustments), the vibration incrementally moved into different speed ranges, incrementally decreased, and road crown became less and less an issue. Measured & aligned each time at Firestone, via my lifetime alignment. I finally settled at 6.5 caster and the drive-ability is pretty damn good, with no wobbles, and I can hold straight on uneven road surfaces & high winds. For reference, I had this conversation with -sean-, and IIRC, he ran 7 on 30s, 35s and 37s on his L-TJ. My neighbor has a very custom XJ, he runs 33s w/ 8 caster, after cutting the inner C's off and rotating them. So I don't drink this lower caster with bigger tires Kool-Aid. I say start someplace and dial it higher until you find something you like.
from: http://www.jeepforum.com/forum/f9/po.../#post14488717
Also from that thread, I mentioned I've tried multiple tricks with a digital angle finder that is about +/- 0.1. What I've noticed on the two housings I've had is a good +/- 1 variation, and that it doesn't necessarily measure the same twice in row. For example, using the socket on the ball joint or lower-C tricks, today might show 6, but next Tuesday may show 5 and the next Tuesday may show something totally different...and none of those necessarily equal what the rack says.
If you're looking to measure caster in your garage, the best I've found is getting it on a laser alignment rack at least once, then relate that to pinion angle measured from a machined surface. Now, for future reference you know you can change the caster and watch pinion angle, and the delta will be the same. This will also allow you to calculate your caster/pinion angle separation.
For example, I recently tried to used two different angle finders to measure caster at ride height by cleaning off the top of the ball joint, and putting the ball joint insertion tool over top of it, and then putting the angle finder on top of that. This is akin to the socket on the ball joint trick, is a pretty tight fit and one would think it will give accurate readings. Nope. The angle finder showed 9 caster (and sometimes 10), which is completely wrong. The laser alignment rack has shown 6.5 caster repeatably over several months...so the garage method was off by at least +2.5 that day.
Basically if you're looking for a correct caster measurement...the only way to know that is start with the alignment rack to get a baseline measurement.
LGriffith 05-16-2009 09:43 PM
Did you get the OME HD springs, or the LJ/ZJ springs? My build's going to be very very similar to this one :thumbsup:
Unlimited04 05-17-2009 04:53 AM
Front: 933 (TJ HD)
Rear: 949 (LJ Specific)
Decided against the ZJ 934 fronts after talking with OME. My friend that helped me install all this has 934 fronts with 949 rears, and he needs 1" rear spacers to sit level.
And if I'm thinking of the bumpstops correctly, I should be good. Baseline is 2" for 33s w/o BL. 2"-1.25" for BL. Leaves 0.75"-0.9" for the homemade bumpstop...which gives me 0.15" extra clearance. Plus theres a spacer in front which gives an extra 0.75".
EDIT-after adding a winch, I went to 934 springs. I'd recommend the 934/949 combo for LJ's, the 933's will work if you're keeping a stock front end with no extra weight.
klimb2xs 05-17-2009 08:20 AM
I had the same thing happen when I replaced my shocks. I just took a dremel with a cut off wheel to the welds. I was able to get one side of each nut cut loose. Then I took a chisel to then and knocked them off.
Originally Posted by Unlimited04 (Post 7234010)
The biggest problem right now is the passenger side rear shock mount: http://www.jeepforum.com/forum/showthread.php?t=778320
I bought a Cobalt tipped drill bit that is supposed to be suitable for drilling hardened steel, that's tomorrows project. Tried to chip the weld-nut off today with a A3 tool steel chisel, it sure busted up the nut, but isn't doing much to the weld. The weld must be 7018 or higher tensile strength stuff.
TheBoogieman 05-17-2009 08:29 AM
Those bolts are a PITA.I snapped 3 off mine.
http://jeephorizons.com/tech/xjshock.html
LJameson 05-17-2009 10:28 AM
Am I the only person in the world that hasn't broken those off? Even at 120,000 miles when I did my lift, the bolts came out no problem. And they were the original shocks...
You pretty much have the build sheet of what I wanted to do to my TJ. I'm probably going that same route when I get back into one too. Maybe even get into an LJ if theres one in my price range.:shhh:
lumpster 05-17-2009 11:19 AM
Ive never had a problem, 4 jeeps and no breaks. Knock on wood!:2thumbsup:
95BadBoy 05-17-2009 12:06 PM
Unlimited04 -
Looking very nice, hopefully you will get that shock in today.
The time now is 10:26 AM.
