Unlimited04's LJ Build - Page 6 - JeepForum.com
 2Likes
post #76 of 711 Old 06-09-2009, 06:40 PM
Jeepguy1977
Jeepguy1977's Avatar
That Rubi Crawler thing is cool....oh wait, won't work with my 32rh
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #77 of 711 Old 06-09-2009, 06:53 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you can get a Klune
a D300 + Klune will fit in a TJ. So should an Atlas + Klune. A supershort NP231 SYE + Klune may fit too.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #78 of 711 Old 06-09-2009, 07:47 PM
mudb8
want it rite or rite now?
mudb8's Avatar
the front lower arms hang up on the shock pad mounts, the rear also hang up on the top of the axle mount with stock ca's. most round aftermarket arms clear both...
you can clearance both...
my rancho arms only hit the fronts with 26" shocks... I raised the rear lower mounts, so I clearanced them..
sorry about the small photo, took me a while to find it. must be why it wasn't in the apropriate album..
I run hard, it yank'd the mount off the axle from pounding on it...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #79 of 711 Old 06-09-2009, 07:56 PM Thread Starter
Unlimited04
what should the eye-to-eye lengths be for front and rear lower CA's with 2.5-3" of lift?
Useful Write-Ups:
Funny:
post #80 of 711 Old 06-09-2009, 09:58 PM
mudb8
mudb8's Avatar
16" works well with stock uppers and keeps enough caster.
mudb8 is offline
post #81 of 711 Old 06-09-2009, 10:20 PM
elkfan2
elkfan2's Avatar
you can get a Klune
Why not just go 4 speed atlas?
elkfan2 is offline
post #82 of 711 Old 06-09-2009, 10:32 PM Thread Starter
Unlimited04
4-speed Atlas: $2875
3-speed Stak: $2900
Klune: $2600
^^damn thats expensive.
My idea:
Rubicon NV241J: $800-1000
AA Rubicrawler: $1600
Total: $2400-2600
Saves a few hundred bucks and doesn't change the drivetrain length at all.
Useful Write-Ups:
Funny:
post #83 of 711 Old 06-09-2009, 10:52 PM
elkfan2
elkfan2's Avatar
3-speed Stak: $2900
Klune: $2600
My idea:
Total: $2400-2600
I would rather spend a few hundred more and have a gear driven transfer case, and I only had to shorten the rear drive line a half inch, so I don't think changing the drivetrain length was a big deal in my case.
elkfan2 is offline
post #84 of 711 Old 06-09-2009, 11:01 PM
mudb8
mudb8's Avatar
I'll be going after the rubicrawler also.. wont' need any new driveshafts, shift linkages... ect.
I'd say since I havn't busted the 241 yet, it'll prolly last a long time...
I do like the atlas tho.. that's for sure
mudb8 is offline
post #85 of 711 Old 06-09-2009, 11:05 PM
elkfan2
elkfan2's Avatar
If I had a 241 I wouldn't replace it for an Atlas, but by the time you buy a used 241 and add a rubicrawler to it its getting too close to the price of a brand new atlas 4 me.
elkfan2 is offline
post #86 of 711 Old 06-10-2009, 07:12 AM Thread Starter
Unlimited04
but you can put a 241 in for the same price as a SYE installed. Run it for several years, then add a Rubicrawler for less than half the cost of Atlas 4-speed once you figure new driveshafts, tub hammering and linkages. I can't afford a Rubicrawler or an Atlas right now. But a NV241J + $20 used Rubicon front driveshaft + 1310/1330 u-joint + Tom Woods rear shaft is doable, and will work forever if I want. Once I do get the money saved for a Rubicrawler, I can install it with zero changes to the drivetrain.
Compare that with an SYE in the NP231, a Teralow in the NP231, then blowing it up. Then going to an Atlas. Thats very spendy for the same result.
Useful Write-Ups:
Funny:
post #87 of 711 Old 06-10-2009, 08:45 AM
klimb2xs
What do you have planned for the 241 linkage? Factory or aftermarket? I thought about reusing my factory stuff, but I did not like the feel of the engagement. After having the Novak 231 shifter I went with their new 241 cable shifter.
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
post #88 of 711 Old 06-10-2009, 12:13 PM Thread Starter
Unlimited04
Interesting, i'll look into that. I was just going to fabricate something if necessary or bend the stock linkage to make it work. Do you have any pics of the cable shifter?
Useful Write-Ups:
Funny:
post #89 of 711 Old 06-10-2009, 06:06 PM
klimb2xs
Here is the only picture I have of it.
It uses the stock lever so you don't have to bend the shift arm like the old models.
klimb2xs is offline
post #90 of 711 Old 06-10-2009, 06:19 PM Thread Starter
Unlimited04
I can't find that on Novak's website.
Question: Anyone know where I can find the speedo tone ring sending unit for the NV241J? The wires are all chewed up on this one. P/N: 05033202AB ??? maybe??
Useful Write-Ups:
Funny:
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
