Unlimited04's LJ Build - Page 19 - JeepForum.com
 2Likes
post #271 of 711 Old 08-28-2010, 07:27 AM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Barrows View Post
How do you like the 33's and the 4.88 gears?
i've only got 8 miles on them - very easy miles. need to finish the 500 mile break-in before i hammer the gears.
but so far, less throttle input and i can keep up with traffic
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #272 of 711 Old 08-28-2010, 07:43 AM
Dogman
Dogman's Avatar
RE: 7/16" - Are you sure you got the correct truetrac?
John 3:17
Dogman is offline
post #273 of 711 Old 08-28-2010, 08:01 AM Thread Starter
Unlimited04
yes, i've verified the part numbers laser marked into the housings. and they fit fine
got the front used locally - was in a 95 XJ HP D30 for 8k miles, rear i got used (but new, never installed) on this forum. both less than 2 yrs old...
I talked to mudb8 and East Coast Gear - seems like a common thing for the D44, but uncommon for the D30. I bought little sleeve/spacer things to be used with the 3/8" bolts. Worked like a charm.
Useful Write-Ups:
Funny:
post #274 of 711 Old 08-29-2010, 08:14 PM Thread Starter
Unlimited04
I had to break in the gears and test the truetrac's with some wheeling ran Red Elephant Hill outside Empire, CO.
Trailhead poser:
Checking for rubbing in front...could probably use 1/2" more bumpstop maybe, but no rubbing was seen.
we added a JK to our group since we were so slow...and COLOUXJ got hung up pretty bad in this technical spot:
Stop for a scenic view (COLOUXJ's the black XJ)
Poser at an abandoned mine site
The gears are AWESOME climbing the highway mountains, I-70 and such. I can actually use OVERDRIVE!!! I still need to kick down into 3rd, but much less. I can actually maintain 65mph in OD on some hills when it used to take 3rd or even 2nd gear. It still shifts and locks up WAY too soon...but thats programming issues of the 42RLE. I can actually set the cruise on the highway and it will maintain speed much better!! And the TrueTrac's performed very nicely...never spun once and walked through everything, even the more technical, slippery, loose rock and dirt stuff.
Useful Write-Ups:
Funny:
post #275 of 711 Old 08-29-2010, 08:20 PM
2006_Sport
How do ya like the duratracs offroad?
2006_Sport is offline
post #276 of 711 Old 08-29-2010, 08:29 PM Thread Starter
Unlimited04
so far they're awesome. way better than BFG ATs.
they're softer so they stick and mold to rocks much better. tread pattern and sidewall lugs are more aggressive, so they claw through the loose dirt and rocks very nicely.
i've tried 30 to 27 psi...still can't get perfectly flat tread wear pattern. I think i'm just going to have to live with the slightly uneven treadwear at 27-28 psi.
the downside to this soft Duratrac compound is they don't last that long...at least not compared to BFGs.
Useful Write-Ups:
Funny:
post #277 of 711 Old 08-29-2010, 08:34 PM
2006_Sport
I got about 15k on mine and they are wearing very well, I expect about 45k. Not as much as the BFGs but still good/
post #278 of 711 Old 08-29-2010, 09:06 PM
JeepnBlake
I'm liking the new tire/wheel combo, looks way better than the black steelies IMO. Are those a load range E tire?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #279 of 711 Old 08-29-2010, 09:48 PM Thread Starter
Unlimited04
yea i'm not a big fan of black steelies...they're cheap and easy to find tho. the new tires are 33x12.50R15's so they're C load rated. The other tires on the 2nd set of steelies were 245/75R16 - E load rated. The 16s are street only now - getting 235/85R16 studded tires (E-load rated).
i'm want to run two sets of tires so I can get to the Coloraod ski resorts in a blizzard, and still have good summer wheeling tires....but nobody makes a true 33" studded snow tire.
235/85R16 and 265/75R16 are the tallest studded tires I can find - both shy of 32". looking at Mastercraft Courser MSR's for winter...neighbor has em on an old F250 and likes em alot. theres plenty of mud tires that are studdable...but i want a true winter tire for the compound and deep siping.
Useful Write-Ups:
Funny:
post #280 of 711 Old 09-06-2010, 09:15 PM Thread Starter
Unlimited04
Wheeling trip: Halfmoon Creek and Mosquito Pass
TrueTrac's did awesome through some tough stuff, even when I had one front tire off the ground - they still grabbed and pulled me through. TrueTrac + Duratrac's did excellent on big rocks, loose dirt, loose rocks, streams, etc...I didn't spin once. Very happy with this choice vs selectable or automatic lockers. No fuss, just point and go, with far better traction
I did learn my front brake lines will rub the shocks pretty bad. I had to modify my Crown extended length to fit on Vanco/Explorer calipers, so they kinda stick upward toward the shocks. When installing the front axle, I either had to point the lines up, where they would rub on the shock at full stuff & full steering lock, or point them down, where they could catch on something and would rub the shock mount/bar pin area...so I picked the lessor of two evils...but looks like I need to do some more grinding on the brake line to get them to clear the shocks.
Still fighting rear driveline vibes.... http://www.jeepforum.com/forum/f9/pu...egear-1095069/
EDIT: More pics-(uploading sucks)
This was the biggest mushroom I've ever seen. Definitely over 12" in diameter. Anyone know wtf it is?
Mule Deer:
At the top of Halfmoon Creek:
Mosquito Pass-
It was so damn windy at the top of Mosquito I hyperextended the drivers door. Broke the plastic housing on the mirror as it smashed into the windshield, put a big dent and long, deep scratch into the door paint as the door hit the fender flare, and completely ripped the kevlar door strap in half. I'm glad i didn't rip the footman loop out of the door...it did bent the sheet metal tho. Where can I get a replacement door strap?
Useful Write-Ups:
Funny:
post #281 of 711 Old 09-06-2010, 09:59 PM
hustler905
^ Jeep looks good!
I think once you get a chance to drive it in the snow, you will love having two Truetracs even more. The front runs just a hair more factory preload than the rear, so in 4-Hi you just gas it a little to pull it straight in a slide (kinda like you do in a FWD car). They make for a very stable and confident ride. I am staying tuned for more tire updates too, the Duratrac might be just what I need.
After seeing that rig, I can say for sure my next Jeep is going to be an LJ.
hustler905 is offline
post #282 of 711 Old 09-07-2010, 07:38 AM
-dirt-
I got one on eBay. Actually, I think it was a pair...
I only needed one for the passenger side, as the wind caught it once and snapped the strap on that side.
I'll look for that leftover strap tonight. If I can find it, you can have it.
-dirt- is offline
post #283 of 711 Old 09-12-2010, 09:48 AM
Jebussaves0
I got these from quadratec after breaking two pairs of door straps:
Armadillo Industries 41190-S - Billet Mechanical Door Stops in Anodized Silver for 87-06 Jeep® Wrangler YJ, TJ & Unlimited - Quadratec
I like them MUCH better
2002 Jeep Wrangler Sahara | 4.0L 5spd D44/D30 3.73s | Hurst Shifter |
| Hummer-Style CAI | 1" Rusty's BL/MML | AA TC Shifter Bracket | 2" BB | JKS Quicker Discos | 33x10.50R15 BFG KM2s | Alpine CDA-9886 HU | OTRATTW Switch Panel | G.P.F. Rear Bumper | Metalcloak Overline Fenders
M416 Trailer | In Progress
Jebussaves0 is offline
post #284 of 711 Old 09-12-2010, 02:48 PM
LGriffith
Looks good!
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #285 of 711 Old 11-15-2010, 07:35 PM Thread Starter
Unlimited04
Added a mudb8 style rear track bar reinforcement bracket. here's how it started:
With lots of grinding and shaping...a few cuss words...
Replaced the stupid factory torx bolt I could never get my torque wrench on due to gas tank clearance. and gawd damn, trying to get the welding stinger in there without a car lift SUCKED. crawling & contortionisms under there with the shocks still connected and the jackstands maxed out at the frame wasn't a lot of fun.
Scored big at the junkyard too:
^^1st gen Grand Prix GTP hood louvers...anyone remember the Oman4x4 write up?
^^windstar airbox cut down, JB welded together, caulked for sealing, and elbow and reducer from Intake Hoses, IntakeTubing, and Intake Clamps
Useful Write-Ups:
Funny:
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
