Unlimited04's LJ Build - Page 16 - JeepForum.com
 1Likes
post #226 of 711 Old 02-02-2010, 10:29 AM
Imped
I followed the same thought process....no worries.
OlllllllO
Float Test Build
IndyORV
Imped is offline
post #227 of 711 Old 02-02-2010, 06:16 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
for those of you with a B&M trans gauge - I did some diagnostics on the temp gauge to find out wtf's going on and come to the conclusion my gauge is defective. sensor spits out a nice, consistent resistance, but the damn gauge sensor output spits out crazy voltages...and the ground wires are dead nuts solid...checked everything with the multi-meter & tested every wire individually.
called up Summit Racing, and all I can say is WOW...these guys have great freakin' customer service. They're sending a whole new kit, and covering the shipping of the defective parts. I didn't even have to give them the order number, knew the account based on caller ID.
Unlimited04 is offline
post #228 of 711 Old 02-04-2010, 09:00 PM Thread Starter
Unlimited04
post #229 of 711 Old 02-04-2010, 09:15 PM
2006_Sport
I just saw that, I thought it would be better in the JKs...apparently not.
2006_Sport is offline
post #230 of 711 Old 02-04-2010, 10:25 PM
glockster
The 42rle lasted 3 months with me and I traded it in for a 6 speed rubi. Probably the best decision I made last year.
glockster is offline
post #231 of 711 Old 03-04-2010, 10:27 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
All these people talk about the beauty of autos, yet I have never had a single issue with my NV3550
EugeneTheTJ is offline
post #232 of 711 Old 03-16-2010, 01:37 PM Thread Starter
Unlimited04
2" OME lift update!
Now that I've put almost 12,000 miles on the 2" OME lift, I decided to check the pinion angle and see if I could get away without the t-case drop.
Before lift - 11.25" to the skid.
If you remember back to page 1, I had 15" of clearance from the ground to the bottom of the skid before the lift settled, with minor vibes. After the 1" t-case drop, it was 14" to eliminate the vibes.
After 12,000 miles on the lift, w/ the t-case drop, 13" to the bottom of the skid, with 7.5 deg pinion angle and output shaft angle...a difference of 0 degrees...perfect!
So, I decided to remove the t-case drop, getting 14" to the bottom of the skid and see if I still get vibes. 5.3 deg output shaft angle and 6.5 deg pinion angle. About a 1 deg difference...not perfect...and I do notice a slight difference smoothness. Will need more miles at different speeds to determine if the drop needs to go back in. I fear if I put the soft top on the rear is going to jump enough to make it an issue.
and 12" to the bottom of the control arm mount.
If you remember back to measurements on page 1, then the actual lift after 12,000 miles is 3" at the t-case skid, and 2.75" at the front lower control arm mount. Had alignment checked again...toe is still good and caster is still at ~5.6 degrees and thrust angle is still the same, which means it hasn't sagged at all in the last 8,000 miles.
post #233 of 711 Old 03-16-2010, 02:46 PM
klimb2xs
Where did you get your digital angle finder? I am tired of fighting with the elcheapo weighted dial ones.
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
post #234 of 711 Old 03-16-2010, 03:14 PM Thread Starter
Unlimited04
- Harbor Freight Tools - Quality Tools at the Lowest Prices
the magnets suck. I've got a rare earth magnet i stick to it for better hold. Its still a POS chinese thing..but it does work.
post #235 of 711 Old 03-28-2010, 03:31 PM Thread Starter
Unlimited04
Originally Posted by rubidriver View Post
You finally did it. I see you did go with the JKS track bar. It looks like you wont be having any trouble with it hitting, although you might need more bumpstop in the front. You are running a hair shy of suggested bumpstop for 33's on those springs.
well rubidriver, you were right. I need more bumpstop to fit 33s. The JKS track bar acts like a 2.5" bumpstop on one side unforunately, but flexing the other side you see I need about 1" more bumpstop for 33s, or highline fenders
JKS track bar vs Riddler diff cover:
This is 245/75R16 (30.5") stuffed in front with the bumpstops completely compressed, and drivers side shocks fully extended (23")
About 1/2" - 3/4" gap all the way around....maybe.
Time to get some hockey pucks!
post #236 of 711 Old 04-20-2010, 04:08 PM Thread Starter
Unlimited04
4/20 update
Rubidriver will like this one
I got the original idea from here: Jeep TJ Air Lift Suspension Installation Write-Up.
and here is my lessons-learned, improved installation guide for installing AirLift bags on a Jeep.
Called up AirLift, found the part number needed for my lift after measuring the springs - #60811. Was about to order them from Summit Racing...but surprisingly enough I found the correct bags on craigslist. They're also used in WK's - guy lifted his WK and the bags didn't fit anymore. $15 A trip to the hardware store for some fittings, and a trip to a bicycle shop for a Shrader valve fitting, and I've got ~$35 into load leveling airbags in the rear. Well...and I rented some spring compressors...but that doesn't count
The manifold, with a drain plug to remove water...its not quite the lowest point in the system, but it will have to do.
Air lines follows the brake lines on the axle housing, and up the control arm.
Made a little bracket to hold the Shrader valve and connected it to the unused locker pump mount on my tummy tuck.
Now technically I have like 1/2" or so too much bumpstop according to AirLift. I decided NOT to remove the OME bumpstop extension because I'm not to sure about using these AirLift bags as bumpstops at this point.
If anything, I was thinking of hacking 1/2" off the jounce bumper.
I went for a short drive and so far I'm very pleased. At 7 psi (5 psi is minimum) it rides exactly the same, and there is no extra lift, the measurement to the t-case skid is exactly the same. At 20 psi it stiffens the springs up nicely and will be awesome when towing or hauling a heavy load. I can't wait to get em off-road now and see how flex is effected.
UPDATE:
I had to modify the jounce bumpers, and reset the bumpstop length for the airbags to work properly.
See part 2 and part 3, and Part 4.
Additionally, I now run these bags off my Viair 460C compressor, the 1 gallon tank and an in-cab precision air pressure regulator ($20 off ebay - but has the necessary larger diaphragm than the pressure regulators you find at your local hardware store, to maintain low pressures). The compressor pumps the tank up to 120 psi, and the air pressure regulator can be set to feed 0-35psi to the AirLift bags in < 1 psi increments.
post #237 of 711 Old 04-20-2010, 05:28 PM
rubidriver
Your right, Rubidriver does like that. He would like it even more if you had used a Rancho OBA to air them up
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #238 of 711 Old 04-20-2010, 09:01 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Nice
Post up how it does on the trail!
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline
post #239 of 711 Old 04-22-2010, 07:36 PM Thread Starter
Unlimited04
actually I think I'm going to go a different route for in-cab controller...eventually. I already have the Viair 460C with 125psi switch, but haven't gotten around to adding an airtank yet. I'll then put a 0-35 psi precision air pressure regulator in the cab, maybe under the seat, hooked directly to the 125psi tank. I'm thinking a ControlAir Type 100 or Type 850.
Type 850 spec- http://www.controlair.com/downloads/850_spec.pdf
Type 100 spec- http://www.controlair.com/downloads/100_spec.pdf
I've used the Type 100 before and it's accurate to 0.01 psi, it actually bleeds off excess pressure or feeds more pressure continuously as necessary to maintain the exact setting specified. You can mount a gauge right to them. Runs about $100. A liquid filled Wika Gauge runs about $20. Add quick disco air fittings & PE air hose and I'm done. Total cost about $125 from Fiero Fluid Power.
post #240 of 711 Old 05-30-2010, 07:12 PM Thread Starter
Unlimited04
updates...
Body Mount
had major body mount issues in the rear, but got it fixed after cutting a hole in the floor.
that thread's here: http://www.jeepforum.com/forum/f9/fi...mount-1019950/
HP D30 Part I
For bushing removal/replacement, I made a bushing press/puller out of 3" OD pipe, a piece of flat plate, some all thread and a bunch of washers & nuts.
Pops the bushings right out-
Pushing a bushing in-
It destroys the all-thread since its such low grade, but the stuff is really cheap & comes in 3 ft lengths, so its not a big deal.
Mount bracing with 1/8" plate:
The LCA's will also get boxed in with my JeepMedic control arm skids, once I cut them off my LP D30 (or I may make new, dunno yet).
Made had originally planned to make a truss from flat plate, like shown earlier. But decided not to use them. Ground clearance for one, but mostly for oil pan clearance at full compression on the top. I didn't want to have to bumpstop things more than I already have, just to keep from hitting the oil pan...besides I still want to fix the track bar vs diff cover issue.
So I took inspiration from never_monday's D30 build here: http://www.jeepforum.com/forum/f9/30...ilt-us-957993/, and started thinking about cross sectional area.
Cut out some sections of ~3" OD x 0.25" wall Schedule 40 pipe which got welded to the long side axle tube...without cutting the original mounts off. Half arsing it probably, but its more than I'll need.
Downloaded the instructions for welding cast iron - Guidelines for Welding Cast Iron | Lincoln Electric
Handbook-Welding Cast Iron
Got four 3/32 55Ni rods from Airgas and had a professional welder do the work. We preheated the cast with a rosebud & IR thermometer, welded it as described, then wrapped it with 4-5 layers of aluminum foil, and wrapped that with fiberglass welding blankets. I have no pictures of this because it was really a two man job...with welding, rotating the housing and maintaining temperature. It took a good 2 hours to cool, so the tin foil method kept the heat in very well. Zero cracks!
Boxed in the UCA mount:
Tapped in an old bushing to make sure things didn't warp-
finished:
So far up to these pictures, I've got $40 into the HPD30 on top of what I paid for it...almost half of which was the nickel welding rod. $65 for the diff cover, dunno if I'll even have to use it. But...coming next in Part II...33s, new ball joints, regear, TrueTracs F/R & Vanco brakes.
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
