Unlimited04's LJ Build - Page 15 - JeepForum.com
 2Likes
post #211 of 711 Old 01-23-2010, 12:45 PM
phittie1100
Good thread - I took my trans swimming at 69k miles, and as you might imagine it was not happy. The trans shop that rebuilt it for me has turned out to be the biggest group of idiots I have ever had to work with, plus they will not install a bung in the pan, claiming it will eventually leak and the mod would void their rebuild warranty. The NAPA T-adapter is exactly what I was looking for - the one concession I got out of the trans shop was them installing a HD trans cooler, but I am having regular trouble with the trans burping up fluid when it gets hot. I need the temp guage so I can see what it is doing, the T-adapter should not give them any cause for grief. My popup is big and heavy, and still running stock 3.73 gears with my 33s does not help the trans run any cooler, especially on hilly, back roads.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline
post #212 of 711 Old 01-24-2010, 11:35 AM
toddallen
Unlimited04, I saw on another thread you talking about gap guards for a body lift. Did you make your own?? If so do you have any pics of it??? I looked through your thread but didn't see anything about it, but I might have over looked it.
2004 LJ Wrangler, 5" Suspension Lift, 1.25" JKS BL, 1" JKS MML, 35"x12.50"x15"
toddallen is offline
post #213 of 711 Old 01-24-2010, 01:03 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Post #130 - Kilby Body Clamz
That what you mean?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #214 of 711 Old 01-24-2010, 01:36 PM
toddallen
No, I was talking about the gap guard in the rear fender well. Between the frame and the body to hide the fact that you have a body lift.
post #215 of 711 Old 01-24-2010, 01:44 PM Thread Starter
Unlimited04
i painted the body with undercoating and flat black paint.
Useful Write-Ups:
Funny:
post #216 of 711 Old 01-24-2010, 01:45 PM
toddallen
I C thanks
post #217 of 711 Old 01-25-2010, 11:46 AM Thread Starter
Unlimited04
I C thanks
it doesn't look bad...if people make fun of it, i'll pull out a tape measure and show them belly clearance of 4" lift & 33s, with 2.5" of lift & 31s... the enormous bike rack hitch looks worse, lol.
Useful Write-Ups:
Funny:
post #218 of 711 Old 01-25-2010, 01:34 PM
rubidriver
I forsee 35s in the near future sir.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #219 of 711 Old 01-25-2010, 02:29 PM
CCJ
this thread is full of win
CCJ is offline
post #220 of 711 Old 01-25-2010, 02:38 PM
CCJ
10 characters
CCJ is offline
post #221 of 711 Old 01-25-2010, 03:54 PM Thread Starter
Unlimited04
you buying em? cuz my 31s are about 5k away from the wear indicators!!
HP D30 is coming well...slowly but surely....waiting till I get everything together before I post progress on it. But heres a hint - I pulled the old Clevite bushings out...it was easy and only took about 15 minutes per side. No fire either.
Useful Write-Ups:
Funny:
post #222 of 711 Old 02-01-2010, 06:29 PM Thread Starter
Unlimited04
I think my B&M gauge crapped out. It's been behaving weird, spiking temps from 140 to 240 in an instant, so I pulled out the multimeter. The sensor gives a nice consistent resistance (about 530 Ohms for ~120 degrees). I can watch the resistance change with temp, so I don't think its a problem. The gauge output to the sensor keeps fluctuating widely....it gives 5.xx volts one sec, then 12.xx volts, then 10.xx volts the next. So the gauge shows 140*F one sec, 240*F the next. Needle bounces all over the place.
Gonna take it apart tomorrow, call Summit or B&M and see what I can figure out.
Useful Write-Ups:
Funny:
post #223 of 711 Old 02-01-2010, 10:15 PM
ankyle62
posting to find this later for post #69, good info.
ankyle62 is offline
post #224 of 711 Old 02-01-2010, 10:27 PM
Imped
Imped's Avatar
I hope you replaced them with a certain Currie product.
OlllllllO
IndyORV
Imped is offline
post #225 of 711 Old 02-01-2010, 10:48 PM Thread Starter
Unlimited04
or you can just click the link in my sig
$12 for 2 Clevite bushings or $160 for the Currie conversion kit....yea so considering i'm a student again...the $12 Clevites won. i'm trying to build this thing for as cheap as possible including regear labor, gears, TrueTrac, master install kit, new ball joints, new unit bearings & truss.
Useful Write-Ups:
Funny:
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
