Quantcast Unlimited Rubicon or Sport Unlimited? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited Rubicon or Sport Unlimited?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
View Poll Results: Unlimited Rubicon or Sport Unlimited?
Unlimited Rubicon..... 76 84.44%
Sport Unlimited 14 15.56%
Voters: 90. You may not vote on this poll
Old 08-21-2005, 11:54 PM   #1
Superstar
I was leaning toward a Rubicon Unlimited, but they are becoming more difficult to find with all this employee pricing going on. I have been to several dealers in the Denver area and they can't get a 2005 Rubi unlimited. Also, this will be my first Jeep, and the only difference I can really see is axles, and rock trac. I will go wheeling, but nothing extreme at this time so I'm not sure if I would take advantage of those upgrades.. So now I'm thinking of just buying the Unlimited sport and then adding after market products as I see fit. so now I torn, sport unlimited or Rubi Unlimited.
Thanks in advance..
Superstar is offline   Reply With Quote
Old 08-22-2005, 12:05 AM   #2
Rocky529
Jeep
Rocky529's Avatar
If you know you're never going to use axle lockers then get the standard Unlimited. It's really up to you.. but I'll vote Rubicon Unlimited since you'll end up using the lockers anyway...
Just so you know... the differences are:
Lockers
31" MT/R tires on 16" MOAB wheels
4.11 gearing in a Dana 44 axle.. Dana 44 front
Lower ratio transfer case
The standard Unlimited comes with 30" tires on 15" Ravine wheels... 3.73 gearing in a Dana 44 rear.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 08-22-2005, 12:07 AM   #3
VegasJeep
wher ei purchased mine in vegas they had about 20 unlimited rubis... most were not listed online... many colors and top options....
another place had about 5 is chapman jeep.
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES
VegasJeep is offline   Reply With Quote
Old 08-22-2005, 12:10 AM   #4
Superstar
Which dealer?
Old 08-22-2005, 12:23 AM   #5
got4-Lo
if ur never gonna wheel it a rubicon is a complete waste. its basically a rock crawler from the factory
stretched *** tj
[URL]webwheeling.com[/URL]
got4-Lo is offline   Reply With Quote
Old 08-22-2005, 03:17 AM   #6
camoTJ
its a good trail runner...wouldnt say its a rock crawler
I would say if you dont see doing many mods to it...small lift little bigger tires then I would go rubi, but if you actully plan to crawl it in the future I would go with the sport because the rubi front axle isnt anything I would want under mine with bigger then 35's anyway ( a dana 30 can handle that) and most the rubi stuff would get swapped out over time so it would be a waste of money
1 tons 106" wb 40's....just like everybody elses
camoTJ is offline   Reply With Quote
Old 08-22-2005, 03:21 AM   #7
camoTJ
oh where at in Denver are ya? if you ever see a beat up camo TJ on 40's rollin by its me. I am in the littleton area
Old 08-22-2005, 03:34 AM   #8
skates04
1997 XJ Cherokee
Some people may or may not want the low gearing of the 4:1
Once again a Jeep Owner
skates04 is offline   Reply With Quote
Old 08-22-2005, 04:17 AM   #9
SCDolphin
I just bought a 05 Rubi c auto and dual hardtops. I really love it but the gas milage is rough..........speaking of rough I think mine had 42psi.....since gas milage is so bad anyway I lowered them to 30psi and is is really a nice ride.....big change fro my F-250.
Good luck
SCDolphin is offline   Reply With Quote
Old 08-22-2005, 07:07 AM   #10
jeeper13
1985 CJ8
shoot, if I lived in Denver I'd go with the Rubi!
Don't forget to :wave:
[COLOR=Lime][B]Parrothead Jeep club member #13[/B] [/COLOR]
[B][URL=http://www.wranglerunlimited.com] [COLOR=DarkGreen][SIZE=3][I][B]www.WranglerUnlimited.com[/B][/I][/COLOR][/SIZE][/URL][/B]
jeeper13 is offline   Reply With Quote
Old 08-22-2005, 08:07 AM   #11
RedRubiconLJ
RedRubiconLJ's Avatar
My unbiased opinion.....Rubicon unlimited
2005 Red Rubi Unlimited Auto
WARN M8000, 3/8 Synthetic line,
Kilby, Jeeperman, Jeepmedic,
RE SF 4.5- all adj arms, RS9000x,
TW shaft, 37" MTr's, RockCrusher,
Currie, Rockhard, Alloy USA.
Jeep Pics
RedRubiconLJ is offline   Reply With Quote
Old 08-22-2005, 08:12 AM   #12
rannasjem
I went with the regular unlimited because I don't do any trails that require lockers and I wanted a limited slip that would do well in the midwest winters. It depends on how you want to build your jeep for your needs.
2004 Solar Yellow Unlimited
2" OME lift - 1.25" Body Lift
33x12.50 BFG Mud Terrains
1946 CJ2A
http://www.BohtTrophy.com
rannasjem is offline   Reply With Quote
Old 08-22-2005, 08:55 AM   #13
RedRubiconLJ
Keep in mind the rubicon has limited slip when the lockers are not in use.
Jeep Pics
Old 08-22-2005, 09:11 AM   #14
yellj
As an Unlimited owner, if I had to do it again I would go with the Rubi, unless you want to build the ultimate trail rig, it is far more cost effective. Don't want to open the debate on whether or not you can build a better rig, you can. If you get into wheeling (it is a sickness) you could put a 4" lift on it and some 33's, have a great looking rig that will handle most anything. By the time I end up locking and regearing I will be a couple thousand behind what I could have bought a Rubi for. and have it covered by the factory.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
www.midatlanticjeepers.com
yellj is offline   Reply With Quote
Old 08-22-2005, 09:16 AM   #15
0IIII0
I was just out this Saturday on a mild trail and the first thing I noticed about everyone on the obstacles is that traction wins. Lockers are awesome, and they will get you into trouble fast! I love my Rubi Unlimited, and I would not have ever gone sport.
[b]SURGEON GENERAL'S WARNING[/b]
Books may introduce unfamiliar or confusing ideas.
In the event of uncomfortable self-reflection,
heat to 451° Fahrenheit and seek television immediately.
"Every argument has a motive, but only the arguments given matter."
[COLOR=SandyBrown]Khaki[/COLOR] Jeep Club Member #[B]28[/B]
Jeep Sahara Club #70
0IIII0 is offline   Reply With Quote
Glock Forum
