Uneven Tire Wear - JeepForum.com
post #1 of 7 Old 01-30-2008, 02:08 PM Thread Starter
djt283
djt283's Avatar
Uneven Tire Wear
I've got a little over 4,000 miles on my 32" BFG AT's. They have not been rotated. I was planning on changing some fluids and rotating them this weekend and I just happened to look and see how they are wearing.
The rear two obviously look new, and the front two only have minor wear. My question is why would the passenger side tire be wearing more than the driver side? It's not a huge difference, but the centerline is worn even on the pass side and not yet on the driver side. Also the edges of the treads have slightly more wear. And yes, they're at the same psi.
Is it possible I just make more left turns?
djt283 is offline
post #2 of 7 Old 01-30-2008, 02:14 PM
Jerky bump
Try jacking the front up and rotating the tires?- one may be dragging more than the other.
Jerky bump is offline
post #3 of 7 Old 01-31-2008, 08:24 PM
87Feep
1987 YJ Wrangler
Pass side always wears more. Primarily due to road crown forcing slightly more of the work to the passenger tire to counteract the crown.
If you're wearing centerline front, sounds like the pressures may be a little high.
87Feep is offline
post #4 of 7 Old 01-31-2008, 10:25 PM
numchuck
pirate squirrel
numchuck's Avatar
maybe not your issue . . . but when you went to the bigger tires, did you decrease your toe-in? the factory service manual and most alignment shops measure it in degrees, so if you are still at the factory specs, then when you put on larger tires, you may have a bit too much.
- Chuck -
the "Dude" abides
numchuck is offline
post #5 of 7 Old 02-01-2008, 06:05 PM Thread Starter
djt283
djt283's Avatar
That was my initial thought, but they are at about 30 (varies with weather obviously...but 30 when warm) It's not wearing too much on the centerline either, just more than the driver's side.
I haven't checked into it any further, but each tire is wearing evenly. Just that the passenger side is wearing a little faster.
djt283 is offline
post #6 of 7 Old 02-01-2008, 06:06 PM Thread Starter
djt283
djt283's Avatar
I hadn't thought of that. It's about 1/16th of an inch right now, but I never though about it in degrees. Not sure I can really decrease it much more though.
djt283 is offline
post #7 of 7 Old 02-01-2008, 09:47 PM
numchuck
pirate squirrel
numchuck's Avatar
Originally Posted by djt283
It's about 1/16th of an inch right now.
that should be good, then.
- Chuck -
the "Dude" abides
numchuck is offline
uneven tire wear Jeepzcb09 TJ Wrangler Technical Forum 10 02-02-2010 01:17 PM
Uneven tire wear PHXYJ YJ Wrangler Technical Forum 8 09-14-2009 06:13 PM
Uneven tire wear stump YJ Wrangler Technical Forum 2 04-14-2006 11:24 AM
Uneven tire wear dr_finklestein TJ Wrangler Technical Forum 9 04-24-2005 11:37 AM
Uneven tire wear? mpadfield TJ Wrangler Technical Forum 7 02-23-2005 07:20 PM
