Uneven tire wear? - JeepForum.com
post #1 of 8 Old 02-23-2005, 04:10 PM Thread Starter
mpadfield
Uneven tire wear?
Okay, so I did a spacer lift. Put in new shocks. Got an alignment. Now I am noticing uneven wear on my front tires. PSI is dead on.
But they are wearing like I am running them too high. (Losing tread in the center.) Caught it early and rotated them, same thing again.
I have talked to tire guys, but they may have been the same ones that did Ron White's van. SO, I thought why not ask the real experts at JeepForum.com?
What have I over looked? Feel free to state the obvious, I won't take offense.
"Someday I'll have the Jeep I always wanted..."
mpadfield is offline
post #2 of 8 Old 02-23-2005, 04:20 PM
Ross
You have too much psi in the tire causing the center to be higher than the side. The psi is max pressure for the tire, jeeps are lighter than many vehicles needing less psi.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #3 of 8 Old 02-23-2005, 04:24 PM Thread Starter
mpadfield
Thanks, but that isn't it. I wasn't clear when I said the PSI is correct. I meant, I am running them light to compensate the weight.
Anyway, that would cause constant problems wouldn't it. Or at least cause the rear to wear that way as it is lighter than the front? Maybe not, but seems logical to me.
Thanks, but that can't be it. Only the front is wearing badly.
post #4 of 8 Old 02-23-2005, 04:30 PM
mud n rox
mud n rox's Avatar
Do the chalk test on your tires. By that I mean mark across the tread with chalk and drive several feet. If the chalk is gone in the center of the tread, you have too much air. If the chalk is gone from the edges of the tire your pressure is too low.
I have 31's on my TJ and did the test to determine the right air pressure. I started at 35 psi and went down. I'm now riding with 30 psi in all tires and get excellent wear. And the ride aint bad either.
2001 TJ Sport - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline
post #5 of 8 Old 02-23-2005, 04:32 PM
Ross
What else could it be? If they both have the same wear problem I wouldn't think both tires are defective. If the bad wear is even around the tire and in the center only I don't think it is suspension.
If the edges wear faster its under inflation, it the center wears faster its over inflation. Thats my thoughts anyway.
Ross is online now
post #6 of 8 Old 02-23-2005, 05:15 PM
wipedawg
wipedawg's Avatar
If the center is wearing out and the center alone.. you need to drop the pressure regardless of what you had it set at before. Lifting it changes steering angles, and caster measurements. Basically just chalk it up and lower the pressure till you have even wear
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #7 of 8 Old 02-23-2005, 05:28 PM
Ol'Blue Jeep
i agree, people are telling you what the probelm is and you keep ignoring it, just try it.
1997 Jeep Wrangler Sport, 4.0, 5-speed, Blue
4" Superlift
Cragar Black "D" Windows
MT Baja Claw Radials 33x12.50
Bestop Sailcloth Replace-a-top
Rhinolined
Cobra CB Radio W/ 100 Watt PA System
Alpine CD Player
Tuffy Dual Compartment Overhead Console
STUDENT JEEP CLUB MEMBER #11
BLUE JEEP CLUB MEMBER #127
Confucius say:
If you want to be happy for a day, get drunk.
If you want to be happy for a month, get married.
If you want to be happy for life, get a Jeep.
Ol'Blue Jeep is offline
post #8 of 8 Old 02-23-2005, 07:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Exactly what tire pressure is in those tires? I hope it's not the same as the tire pressure that is molded onto the sidewall.
Jerry Bransford is online now
uneven tire wear Jeepzcb09 TJ Wrangler Technical Forum 10 02-02-2010 01:17 PM
Uneven Tire Wear djt283 TJ Wrangler Technical Forum 6 02-01-2008 09:47 PM
Uneven tire wear stump YJ Wrangler Technical Forum 2 04-14-2006 11:24 AM
Uneven Tire Wear 58dDriver TJ Wrangler Technical Forum 1 04-08-2006 01:23 PM
Uneven tire wear Moxzart TJ Wrangler Technical Forum 6 08-06-2005 08:04 AM
