Uneven brake wear? - JeepForum.com
post #1 of 3 Old 12-26-2003, 03:22 PM Thread Starter
zband
zband's Avatar
Uneven brake wear?
Jeep 2003 with four wheel disc brakes- I've noticed that when cleaning the rims the passenger side rim has an excessive amount of brake dust. I have a feeling that that rake is doing most of the stooping. Is there any way to tell if the pads are pressing with the same force on all four wheels?
zband is offline
post #2 of 3 Old 12-26-2003, 04:03 PM
swoodnj
swoodnj's Avatar
Not that I'm aware of, you could do a bleed at all 4 corners to make sure. Did you get the Jeep new?
Steve W
PS. Noticed your sig, running 10.3 on a dual 1.25 here.
04 TJ X 4.0L 5 spd
Bright Silver Metallic Clear Coat Exterior Paint Club member #18
swoodnj is offline
post #3 of 3 Old 12-26-2003, 04:20 PM
halfmoonclip
Z-
Does it PULL under braking? Is one wheel warmer than the other?
The front brakes SHOULD be doing a lot of the stopping, so compare front to front.
If the calipher is binding, you may be wearing an the outside lining more rapidly than the inside.
Put it on jackstands and pull the wheels; you should be able to see the upper end of the lining with a good light; are they worn about the same?
Good luck; if it is unusual wear, the warranty should cover it.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
uneven tire wear Jeepzcb09 TJ Wrangler Technical Forum 10 02-02-2010 01:17 PM
Uneven tire wear PHXYJ YJ Wrangler Technical Forum 8 09-14-2009 06:13 PM
Uneven tire wear stump YJ Wrangler Technical Forum 2 04-14-2006 11:24 AM
Uneven Tire Wear 58dDriver TJ Wrangler Technical Forum 1 04-08-2006 01:23 PM
uneven brake pad wear ?? jeepinjc YJ Wrangler Technical Forum 7 01-18-2006 08:46 AM
