Uneven Brake Wear - JeepForum.com
post #1 of 11 Old 12-18-2010, 11:00 PM Thread Starter
PDX_XJ
PDX_XJ's Avatar
Uneven Brake Wear
I had a loud squeal from my front passenger wheel above 20mph. Assumed the brakes on that side were down to the squealer, so I swapped my brake pads. Good thing, since the driver's side pads were nearly gone.
The rotors looked fine, so I re-used them without machining. Old calipers were re-used as well, but now I'm questioning them.
Here's what the wear on the old one's looked like.
Driver's Side: Nearly gone, but the side the outside pad (away from the piston) had more meat on it. -- 1/8" vs 1/16"
Passenger Side: About halfway gone, but the inside pad (piston side) had more meat on it. -- 1/4" vs 3/8"
When I compressed the driver's piston back into the caliper, it took a lot of force at first, but loosened up. It was nearly all the way out due to the nearly gone pads, of course, so I don't know if that was an issue.
Question is: I understand a sticking caliper would cause one side to wear more than the other (driver vs. passenger), but what would cause an outside pad to wear differently than the inside pad? And why not the same way on each side?
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline
post #2 of 11 Old 12-19-2010, 12:31 AM
Cjensenr
I have experienced this in the past. The sleeve freezed up. Another time it was the calipers. I would personally redo the calipers and disc/drum.
c.
Cjensenr is offline
post #3 of 11 Old 12-19-2010, 09:23 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You can get the calipers and new rotors and DIY.
TheBoogieman is offline
post #4 of 11 Old 12-19-2010, 10:19 AM
johnny9
i abuse my stock brakes so much i gave up on perfection till the d60 and disks all around are on in a few months..replaced my caliper and brakes and lines 3 times to stop a rattle i have from the caliper and decided i have a bent knuckle..it stops fine but i hate noises lol..good luck
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #5 of 11 Old 12-19-2010, 10:29 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
The uneven pad wear is caused by a design flaw in the knuckles. The pads catch on the sliders, end up digging a divot into the cast iron knuckle, and the caliper can't apply even force across the brake pad. The knuckles also flex/warp with much of the braking force being applied to the knuckle, not the rotors.
http://www.jeepforum.com/forum/f9/xj...rooves-924713/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 11 Old 12-19-2010, 10:30 AM
scottbr
2016 JK Wrangler
So, what's the fix? grind the sliders flat again?
scottbr is offline
post #7 of 11 Old 12-19-2010, 10:32 AM
55willystruck
X2 and precisely why the Vanco kit was build and why they include new beefed up knuckles to prevent future issues, along with better braking all around...
Not saying you have to switch BUT this is the inherent flaw with the system. I noticed it in my '05 brand new off the lot the brakes weren't up to par, and by the time the original 15" test kit was shipped, I had already developed uneven wear in my rig at a very early mileage. There are definitely other options but the Vanco is the best by far as a "complete" system.
Best of Luck,
Mike
55willystruck is offline
post #8 of 11 Old 12-19-2010, 10:33 AM
Unlimited04
the link to fix it is in my sig.
Useful Write-Ups:
Funny:
post #9 of 11 Old 12-19-2010, 10:40 AM
55willystruck
Unlimited-
Wanted to say Thanks for the links in your sig-you have some very good info there. Nice work.
Best of Luck,
Mike
post #10 of 11 Old 12-19-2010, 10:43 AM
Unlimited04
Originally Posted by 55willystruck View Post
Unlimited-
Best of Luck,
Mike
Thanks
sometimes I don't think anyone reads that stuff...
Useful Write-Ups:
Funny:
post #11 of 11 Old 12-19-2010, 10:56 AM
johnny9
Thanks
just so you know,,i think we all read it lol..we just dont always reply
merry christmas
build-
johnny9 is offline
Uneven Tire Wear djt283 TJ Wrangler Technical Forum 6 02-01-2008 10:47 PM
uneven brake pad wear ?? jeepinjc YJ Wrangler Technical Forum 7 01-18-2006 09:46 AM
Uneven tire wear Moxzart TJ Wrangler Technical Forum 6 08-06-2005 09:04 AM
Uneven tire wear? mpadfield TJ Wrangler Technical Forum 7 02-23-2005 08:20 PM
Uneven brake wear? zband TJ Wrangler Technical Forum 2 12-26-2003 05:20 PM
