Undercoat, Bedliner, or Carpet to line TJ Hardtop - JeepForum.com
post #1 of 12 Old 06-02-2012, 09:46 AM Thread Starter
terpsmandan
2009 JK Wrangler
I am looking into trying to insulate and quiet my hardtop for winter and I have seen people use all of these methods. I was also thinking about using Dynaliner as well. All opinions would be appreciated.
terpsmandan is offline
post #2 of 12 Old 06-02-2012, 02:01 PM
blake32
IMO, sprayed-in, not roll-on bedliner is best. It provides some structural integrity.
blake32 is offline
post #3 of 12 Old 06-03-2012, 07:07 PM
Erik T.
Erik T.'s Avatar
Structural integrity?
I love to hear how you came to that conclusion.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #4 of 12 Old 06-03-2012, 08:31 PM
J03_TJ
As far as insulating, I have been pondering this during the winters for a few years. I saw a post or two quite a while back where someone got there hands on I believe what was sold as a yoga mat. it was foam that could be cut to size and adhered to the underside of the hardtop. It had a pretty tough skin on the surface so it had a nice finished look if I recall. Might not be what your thinking of, but thought I'd mention what I had seen. My only concern was how good of an adhesive I could get my hands on that would stop it from creeping off during the hot summer months.
J03_TJ is online now
post #5 of 12 Old 06-03-2012, 09:53 PM
ColoradoCole
Try using speaker box covering before you use carpet, my hardtop is getting this done to it at the moment, when i get it back i will post picks. The guy said that it is easier to mold with and glue on than marine style carpet it, and it is more sound dampening
ColoradoCole is offline
post #6 of 12 Old 06-04-2012, 09:19 AM Thread Starter
terpsmandan
2009 JK Wrangler
Most people here that use cloth use 3m adhesive. How much is one of those yoga mats?
post #7 of 12 Old 06-04-2012, 09:33 AM
bustedknuckle
A hard top sprayed with line-x would offer better structural integrity.
bustedknuckle is offline
post #8 of 12 Old 06-04-2012, 09:47 AM
Sundown1
I carped the inside of my hard top last year (white hard top) I really liked it this past winter. I bought some gray indoor/outdoor carpet & used the 3m spray on glue. Held up really well. It helped on the temperature as well as sound - plus it looked a lot better than just the white hard top. There are some pretty good posts showing pictures and the easiest way to do it.
Good luck
Sundown1 is offline
post #9 of 12 Old 06-04-2012, 10:13 AM
J03_TJ
I'm not sure in the mat cost, I only mentioned it in case you wanted to search on it or just to mention that foam with a skin on it might be an option. I could only guess that the pad might have been around $50, and I'd bet it would take two because of the surface area though.
post #10 of 12 Old 06-04-2012, 11:21 AM Thread Starter
terpsmandan
2009 JK Wrangler
That sounds intriguing. I will look into it.
post #11 of 12 Old 06-04-2012, 12:54 PM
NHEric
I used a bunch of carpet padding and a piece of indoor/outdoor carpet (the kind with no rubber backing). I got the padding at the local flooring shop. It was free. The carpet stuff was stupid cheap. Got it at walmart. Used the 3M adhesive and went for it. I also painted the rest of the top with Krylon Fusion. Worked awesome. It's been in for 3 or 4 years now. It's quieter going down the road than my Dodge. Keeps heat in way better, too. My favorite part is that it's not white anymore. Got really sick of how bright it was inside the Jeep every time a car got behind me at night.
NHEric is offline
post #12 of 12 Old 06-04-2012, 04:32 PM Thread Starter
terpsmandan
2009 JK Wrangler
Thanks. That's probably how I will go. I am all for cheap.
Hardtop bedliner goolsbayjeep Wrangler General Discussion 0 04-23-2011 10:26 PM
Line-X to COVER other bedliner? Seal TJ Wrangler Technical Forum 6 03-30-2011 12:55 AM
carpet or bedliner? Nick_Knipp YJ Wrangler Technical Forum 30 11-18-2010 11:32 AM
Line-x red bedliner newvances YJ Wrangler Technical Forum 12 06-25-2007 12:16 PM
No carpet / bedliner - what did you do here? ImaginaryFriend TJ Wrangler Technical Forum 14 04-16-2007 06:25 PM
