Undercarriage Rust and what to do to fix/prevent it? - JeepForum.com
post #1 of 14 Old 03-13-2007, 08:32 AM Thread Starter
Sparty
Sparty's Avatar
2004 TJ Sport - ~50,000 miles.
This is my first hard winter in Michigan with the Jeep. I crawled underneath it yesterday and the undercarriage is starting to look rough because of rust. Iíve been through 1.5 winters out in Iowa, but they must use a TON more salt in Michigan.
I donít think Iíll be able to get to everything with POR 15 because of limitations on the equipment I have and have access to.
Does anyone know of an actual undercoating that works? A company that I can get to do it?
Or any other suggestions? TIA!
Sparty is offline
post #2 of 14 Old 03-13-2007, 08:56 AM
Rocky529
Rocky529's Avatar
Jack it up, remove all the wheels, and have a field day with POR-15. Clean your frame, use a wire brush to clean it up... then just paint everything with POR-15.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 14 Old 03-13-2007, 08:59 AM
cleanhull
Move out of the rust belt. I feel your pain though.
cleanhull is offline
post #4 of 14 Old 03-13-2007, 09:04 AM
Combatsylvania
take it to a place that does Krown oil rust protection... that stuff is amazing.. they fill your frame and body panels..
periodically get a rinse doen through the winters
i feel your pain man, they salt the roads 5 months out of the year up here.
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #5 of 14 Old 03-13-2007, 09:08 AM Thread Starter
Sparty
Sparty's Avatar
Is that just in Canadia, or is there any in the US? I'll look in the meantime. Thanks!
Sparty is offline
post #6 of 14 Old 03-13-2007, 09:32 AM
GW
2015 JK Wrangler
Waxoyl from Rovers North works really well. Its a parafin spray on oil/wax undercoating. Easy to apply and lasts about 2-3 years. Cheap. One can did my entire TJ. Just powerwash the undercarriage, clean off the surface rust, then waxoyl it. Its a lot easier to use that painting your frame, etc. Years ago I had a 86 Blazer that I rust proofed by spraying WD 40 into the door drain holes, fender wells and inside the frame rails. I drove that truck through 16 Michigan winters and the only rust it had was surface from scratches. Somewhat messy, but using WD 40 was cheap and really effective rust proofing.
GW is offline
post #7 of 14 Old 03-13-2007, 09:36 AM
MotownTom
This stuff is available all over and performs as advertised.
Runs about 6 or 7 bucks a spray can.
http://www.permatex.com/products/aut..._Treatment.htm
'05 Black Rubi 6-spd
MotownTom is offline
post #8 of 14 Old 03-13-2007, 10:26 AM
Combatsylvania
Canadia? lol..
Uhm, no I think they carry it in the states... its like undercoating, but its only oil..
Krown Rust Control System is what its branded up here... ask any "quick lube" type palce about it, they can probably direct you to a shop, or something similar.
post #9 of 14 Old 03-13-2007, 10:41 AM
Jerky bump
Yeah, Krown,Rust check, both pretty good. Something a little heavier is better underneath. I like Fluid Film for underneath. I'm considering Rhino guard with a Krown followup.
Jerky bump is offline
post #10 of 14 Old 03-13-2007, 10:43 AM
LarrySchwegman
If you decide to DIY. No matter what product, don't forget to protect yourself. Face, hands, arms, eyes. I did my truck frame last summer in gloves and a t-shirt. I had black freckles all over my face and arms for a week. If you use POR don't forget the UV top coat. I figured being the underbelly that it wouldn't fade. I was wrong, and now I have to do it again this summer.
LarrySchwegman is offline
post #11 of 14 Old 03-13-2007, 11:02 AM
1BadJeepX06
The average price for getting your frame Line-X'd around here is $300.. Sure it's a bit pricey but it'll last for the life of your Jeep and 9 out of 10 places do free touch-ups for the life of the vehicle..
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #12 of 14 Old 03-13-2007, 12:13 PM Thread Starter
Sparty
Sparty's Avatar
if POR 15 fades, does it need to be odne over again, or are you just doing it for color?
Thanks to all for the replies!
Sparty is offline
post #13 of 14 Old 03-13-2007, 12:57 PM
mountaineerjp
no...the properties of por-15 are not affected if it fades.
1997 Sahara - 2.5"OME HD Springs and 2" BB - Bilstein 5100s - 35" BFG KM2s - Doug Thorley Header - Warn M8000 - Nates 4x4 Front & Rear Bumpers - JeepMedic Engine Skid - Shrockwork Rockers - OR-Fab Sport Cage - Ford 8.8 - 4.10s - TNT Customs 4.5" Tube Fenders in Front and Rear - Viking Soft Top - many other mods
WEST VIRGINIA UNIVERSITY
Every normal man must be tempted, at times, to spit on his hands, hoist the black flag, and begin slitting throats. - H. L. Mencken
mountaineerjp is offline
post #14 of 14 Old 03-13-2007, 02:52 PM
Jamesdt007
6 cans of 3M Rubberized Undercoating
Jamesdt007 is offline
Good way to prevent new rust??? JAC1502 TJ Wrangler Technical Forum 18 08-27-2011 05:59 PM
How Do I Prevent Rust on the Exhaust? mramella JK Wrangler Technical Forum 11 11-09-2009 12:10 PM
can anything prevent rust? MC_NickP TJ Wrangler Technical Forum 5 01-01-2009 09:01 PM
undercoating to prevent rust? 'B'wigstrailrig TJ Wrangler Technical Forum 8 12-11-2006 08:11 AM
Anybody use this to prevent rust? Butters98TJ TJ Wrangler Technical Forum 0 01-01-2005 10:41 PM
