Under Cover Fabworks aluminum tummy tuck install pics - JeepForum.com
post #1 of 608 Old 01-30-2010, 01:30 PM Thread Starter
661
This is the version where a 1" body lift is required; or highly recommended. UCF also offers skids that do not require a body lift. You can also choose between aluminum, carbon or stainless steel. Nice!
See their website for details: Under Cover Fabworks, LLC - undercoverfab.com - Main Page
The skid arrived sans a shipping carton:
Welds:
This one is titled, Beauty and the Beast.
Minor clearance issue with my exhaust. Nothing a little grinding can't fix. Matt at UCF is looking at adding a cutout in future.
And the obligatory before and after shots:
Except for having to clearance for the muffler, this was a quick and easy mod.
Overall clearance gained was 1 5/8" over stock (note: as measured from the absolute lowest point on both skids). A little less than advertised but I'm not complaining considering the price of this skid.
Up-travel in the drive train came to 1.5"; measured from tranny mount stud to the ground.
Drive shaft length did not measurably change.
Took the jeep for a test spin and felt nary a vibe. Shifting even feels better with less strain on the boots after the BL. Granted I had all the pre-reqs for this mod so your mileage may vary.
FYI, I have no connection to UCF. Just a satisfied customer... so long as this bad boy can take a lickin'.
search tags: under cover undercover fabworks fab ucf tummy tuck tucker bellyup belly up skid crossmember aev rokmen savvy
661 is offline
post #2 of 608 Old 01-30-2010, 01:34 PM
wrangler2007
looks good. what was the weight comparison between the stock one and the ucf?
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline
post #3 of 608 Old 01-30-2010, 02:07 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Opps...Looked again...
Looks NICE!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #4 of 608 Old 01-30-2010, 02:14 PM Thread Starter
661
Ahem... that's a mint green "Blob", sir!
I need better lighting...
661 is offline
post #5 of 608 Old 01-30-2010, 02:22 PM
SuperWade2
SuperWade2's Avatar
I guess you saw the question before I removed it... I'll blame my Laptop screen for not being able to distinguish carpet pile in the corner cutout of your skid...
2017 WK2 Overland
post #6 of 608 Old 01-30-2010, 04:54 PM Thread Starter
661
UCF Alu is ~12lbs lighter than stock.
Versus aftermarket skids made of steel... you're looking at a weight savings in the neighborhood of 50lbs.
661 is offline
post #7 of 608 Old 01-30-2010, 05:03 PM
rs4race
I thought you were supposed to get 2.5" extra clearance, with a drive train raise of 1.5"??
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #8 of 608 Old 01-30-2010, 05:08 PM
rs4race
nvm went back and re read their site. I could have sworn in a post on here I read 2.5" and 1.5" tho.
My Build
rs4race is offline
post #9 of 608 Old 01-30-2010, 06:54 PM
Shakey
2.5" for 2003+.
Shakey is offline
post #10 of 608 Old 01-30-2010, 08:44 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you're not going to paint it?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 608 Old 01-30-2010, 10:01 PM
SnowYJ
1988 MJ Comanche
definitely made my mind up on this one. will be getting the non'BL verion though.
I go to college and I drive a Jeep.
SnowYJ is offline
post #12 of 608 Old 01-30-2010, 10:41 PM
rs4race
polish it up a little. yeah its gonna get dirty and scratched. I just got some aluminum rocker guards, unfinished. I took some 600grit sandpaper and some mothers aluminum polish and they look 1000x better. You probable dont care since the skid is under your jeep and not on the side tho.
My Build
rs4race is offline
post #13 of 608 Old 01-30-2010, 10:48 PM Thread Starter
661
Might black it out with a rattle can at some point. No particular hurry, though, b/c it won't rust.
661 is offline
post #14 of 608 Old 01-31-2010, 09:10 AM
jgorm
jgorm's Avatar
aluminum will corrode, especially if there is salt around. I've seen 1/4" aluminum on boats turn to dust.
jgorm is offline
post #15 of 608 Old 01-31-2010, 09:36 AM
Unlimited04
x2. aluminum doesn't rust. but it does corrode. brown rust is just corrosion specific to iron based metal...
the main benefit to aluminum is it inherently has a thin ceramic aluminum oxide layer coating on it from interaction with the atmosphere...but it can be easily scrapped away.
Aluminum pitting:
Useful Write-Ups:
Funny:
install pics, Tummy tuck, sye,driveshaft, etc FLATFENDER54 TJ Wrangler Technical Forum 31 09-10-2012 11:26 AM
Is it possible to install a mml and Tummy tuck without a body lift blackruby56 TJ Wrangler Technical Forum 6 08-31-2009 02:55 AM
33 Engineering Tummy Tuck Install Problems 05jeeper TJ Wrangler Technical Forum 20 12-22-2008 08:54 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
Aluminum Valve Cover install notes MaineYJ YJ Wrangler Technical Forum 0 02-26-2006 05:42 PM
