Undecided: 33 or 30 Spline D44 - JeepForum.com
post #1 of 16 Old 09-17-2007, 12:32 AM Thread Starter
Humboldt
Humboldt's Avatar
Im taking the jeep for a regear to 4.88's this comming week. Im going full Detroit in the rear with a lock-right upfront on 35" MT/R's. What I can't decide on is if I want to bother upgrading the rear to 33 splines at the same time or not.
I realize the 33 splines are stronger, but if I stay with the 30 spline, I can use the stock shafts as spares. If I go with 33 splines, I would have to buy another set and get the bearing/backing plate pressed on etc.
Thinking down the road, I can also see finding 30 spline shafts in a pinch would be much easier on trips. I drive to/from wheeling and driving home on just the front is not something I care to repeat often.
Any advise?
Humboldt is offline
post #2 of 16 Old 09-17-2007, 01:23 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Mas Grande. Google it.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #3 of 16 Old 09-17-2007, 01:49 AM Thread Starter
Humboldt
Humboldt's Avatar
Yeah, I know the options. Just looking to see if its worth it ease of parts vrs strength.
My Battalion is flying into Va Beach (Oceana) for 3 days before going home Grew
Humboldt is offline
post #4 of 16 Old 09-17-2007, 01:58 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Ooohhh... Well I tell you what, check your PMs and give me a call when you get here. I work mids on Oceana Sunday - Thursday.
Anyway, the Mas Grande kit comes with the 35 spline shafts, an ARB, seals and bearings. All of this for $1100. Honestly I don't think that price can be beaten for what you're getting.
Andy, KD8EIA
Grewe02 is offline
post #5 of 16 Old 09-17-2007, 04:27 AM
SteelBlueTJ
I would go with a set of new shafts from Alloy USA. Get the 30 spline and they will be alot stronger than stock. The 30-spline Alloys are pretty tough. I don't really see the need to go to 33 spline. I've had my 30spline alloy's for over a year now on with 35" MTR's with no problems.
SteelBlueTJ is offline
post #6 of 16 Old 09-17-2007, 04:39 AM Thread Starter
Humboldt
Humboldt's Avatar
Originally Posted by SteelBlueTJ
I would go with a set of new shafts from Alloy USA. Get the 30 spline and they will be alot stronger than stock, but still 30 spline- meaning you can use your any oem ones as spares still. The 30-spline Alloys are pretty tough. I've had them for over a year now on 35" MTR's with no problems.
Exactly what I was thinking. Still open to input though.
Thanks for the reply.
Humboldt is offline
post #7 of 16 Old 09-17-2007, 09:51 AM Thread Starter
Humboldt
Humboldt's Avatar
maybe I should add a poll
Humboldt is offline
post #8 of 16 Old 09-17-2007, 10:18 AM
ptowntj
ptowntj's Avatar
I've got the 35 spline alloy usa shafts (is that the mas grande?)...not much use on them yet, but the way I look at it, if you guys aren't breaking them with the alloy 30 spline, then the 35 spline is extra security.
8 lug xj.
ptowntj is offline
post #9 of 16 Old 09-17-2007, 10:20 AM
jeeptillidie
jeeptillidie's Avatar
D60
that is my opinion
jeeptillidie is offline
post #10 of 16 Old 09-17-2007, 10:32 AM
ptowntj
ptowntj's Avatar
Originally Posted by jeeptillidie
D60
that is my opinion
and your opinion is completely unrelated to what the OP is asking. He's looking to regear, not do an entire axle swap.
8 lug xj.
ptowntj is offline
post #11 of 16 Old 09-17-2007, 10:54 AM
mdm
Farm Wheeler
D60
that is my opinion
You do like the D60. Seems like it's the answer to any rear axle problem.
mdm is offline
post #12 of 16 Old 09-17-2007, 11:00 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you go with an aftermarket hardened chromolly 30 spline like from Alloy USA or Superior axle, you can stick with 30 splines. I already twisted the splines off my stock 30 spline OE axle (Detroit Locker and 35" tires) but I haven't had any problem since upgrading to Alloy USA's beefed up 30 spline alloy axles.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #13 of 16 Old 09-17-2007, 02:34 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
personally i'm running factory 30 splines detroit rear, and 36s. I have twisted a 44 shaft a little, but not really bad. I have had a set of alloy shafts for a while and am just now installing them.
my bet is keep the 30s and upgrade to alloys or something like that. That way you have a spare set.
it's your money though.
one of the local shops is running a 33 spline ARB 44 with 37s. works great as well.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #14 of 16 Old 09-17-2007, 02:39 PM Thread Starter
Humboldt
Humboldt's Avatar
Yeah, Thanks for all the input. Im just gonna go with the USA Alloy 30s and keep the stockers for spares.
Humboldt is offline
post #15 of 16 Old 09-17-2007, 02:49 PM
VinoTJ
VinoTJ's Avatar
Only problem with 33 or 35-spline shafts is quick replacements if you break one. You would/should not have a problem getting a quick replacement for a 30-spline shaft.
2008 Wrangler Unlimited X
VinoTJ is offline
Superior Chromo D30 (30 Spline)/D44 (35 Spline) Axle Shaft P/N's??? SuperWade2 TJ Wrangler Technical Forum 2 01-02-2010 08:24 AM
undecided on what all terrains to go with mossman07 TJ Wrangler Technical Forum 29 02-15-2009 02:24 PM
Undecided on LA and SF again...HELP! wrangler2007 TJ Wrangler Technical Forum 3 11-15-2008 02:16 PM
Undecided with my jeep virtuaillusion YJ Wrangler Technical Forum 3 06-01-2005 09:21 PM
dana35 27 spline to 30 spline w/detroit autolocker?? good mod? colorado_jeep TJ Wrangler Technical Forum 8 10-02-2002 05:43 AM
