Unable to get grease into JKS trackbar grease fitting anymore - JeepForum.com
 1Likes
  • 1 Post By mrblaine
post #1 of 4 Old 04-20-2016, 07:31 PM Thread Starter
bandofjeepsys
My Jks trackbar is about 6 years old. I tried replacing the grease nipple fitting but it still won't take any grease. It took grease just fine until recently. Am I going to have to replace the trackbar??
bandofjeepsys is offline
post #2 of 4 Old 04-20-2016, 08:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
No, just disconnect the axle end and swing it around and move it up and down while trying to put grease in. What has happened is the lube oil has left the binder in the grease and the binder has dried out leaving the passages clogged. Sometimes moving the races around on the ball will let the new grease displace the binder and flush it out.
If not, then you'll have to disassemble the JJ and clean it out, reassemble it with some grease and it will be fine.
bandofjeepsys likes this.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 4 Old 04-20-2016, 08:41 PM
flying2275
The JKS trackbars are rebuildable so you shouldn't need to buy a new one. Press out the bushings if you have to and clean the passages with some thin wire.
flying2275 is offline
post #4 of 4 Old 04-21-2016, 09:07 AM Thread Starter
bandofjeepsys
Thank you so much mrblaine and flying2275 for the awesome help!!
