Uh oh, angry sparrow is on to me - JeepForum.com
post #1 of 9 Old 06-11-2006, 04:15 PM Thread Starter
jzmtl
jzmtl's Avatar
Looks like my front ujoint is on it's way out. Now the question is, when do I HAVE to replace it.
Right now the chirping can only be heard at low speed, say around 20, with radio off. Does it become louder over time to give me some sort of indicator on needing replacing, or is it gona stay this way and just blow up one day?
What to do?
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline
post #2 of 9 Old 06-11-2006, 04:19 PM
redvett94
You need to change it ASAP. Waiting will cost a bundle if anything breaks.
2000 Sport.
redvett94 is offline
post #3 of 9 Old 06-11-2006, 04:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just remove the front driveshaft until you can afford to replace the u-joints. It's easily removed, just 8 u-joint strap bolts hold it in place.
Getting
Jerry Bransford is online now
post #4 of 9 Old 06-11-2006, 04:44 PM Thread Starter
jzmtl
jzmtl's Avatar
Any recommendations on what ujoint to use, or should I go to dealer for it?
jzmtl is offline
post #5 of 9 Old 06-11-2006, 04:48 PM
Jerry Bransford
Administrator
Just a standard Spicer 1310 u-joint. Any driveshaft shop will have them and if you like, they will replace it for you MUCH cheaper than the dealer will.
Getting
post #6 of 9 Old 06-11-2006, 05:34 PM Thread Starter
jzmtl
jzmtl's Avatar
How difficult is it to replace for a novice mechanic? Also, would it be able to go for a month without problem? Because right now I don't have a place to do it, and will have to pay some shop to.
jzmtl is offline
post #7 of 9 Old 06-11-2006, 05:46 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
*EDIT* - Disregard
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #8 of 9 Old 06-11-2006, 05:56 PM
Jerry Bransford
Administrator
While it's not difficult, it's not a job for a novice mechanic who doesn't have a place to work. You didn't clarify if the front u-joint is in the front or rear driveshaft but if it's in the front driveshaft, I would just unbolt and remove the front driveshaft for now.
If the bad front u-joint is in the rear driveshaft, you need to get it replaced asap because you sure don't want the u-joint coming unglued and the front of your driveshaft dropping to the road as you drive!
Getting
post #9 of 9 Old 06-11-2006, 06:56 PM Thread Starter
jzmtl
jzmtl's Avatar
Right now I couldn't tell exactly which u joint is it, but sounds like the one connect front driveshaft to pinion. I read the writeup on stu's site, by jeeper, dosen't seem hard. Right now I don't have a place to work but in a month I will.
Although it seems like a pain in the *** to get the bolts that hold the shaft to the TC. (and I have no idea how will I able to get the bolt in there when putting it back on...)
jzmtl is offline
Not Angry Sparrow, What Next? MetalguyH TJ Wrangler Technical Forum 11 12-08-2009 05:18 PM
Angry Sparrow Pags54 TJ Wrangler Technical Forum 4 01-09-2007 06:43 PM
No Angry Sparrow? pharmacist25 TJ Wrangler Technical Forum 5 12-04-2006 04:02 PM
Another Angry Sparrow Problem Krisfyr TJ Wrangler Technical Forum 7 01-01-2006 08:54 PM
angry sparrow? shadows_lair TJ Wrangler Technical Forum 3 01-23-2005 08:32 PM
