UFC engine skid install help please... - JeepForum.com
post #1 of 21 Old 07-03-2010, 01:17 PM Thread Starter
kllrbee
Hey all,
Just got the aluminum one from a member on here. Looks pretty easy to install. But I was wondering for those of you who have the stock TC skid, did you bolt engine skid on top of TC skid or bottom? some pics might help. Thanks.
BTW, 04, 4" SL, no MML.
To Alcohol!...The cause and solution to all of life's problems. - Homer
kllrbee is offline
post #2 of 21 Old 07-03-2010, 01:25 PM
Jay12
Bolt it to the bottom of it. Loosely bolt up the front brackets and then use a floor jack to hold the skid under the TC skid to mark the holes you need to drill. Drill holes and tighten all bolts.
Jay12 is offline
post #3 of 21 Old 07-03-2010, 02:02 PM Thread Starter
kllrbee
Alright, thanks Jay.
Yeah it looked like it didnt fit right if I went on top of TC skid.
kllrbee is offline
post #4 of 21 Old 07-03-2010, 03:47 PM
Benderff
Benderff's Avatar
Glad it finally made it!
Benderff is offline
post #5 of 21 Old 07-03-2010, 11:05 PM Thread Starter
kllrbee
Oh yeah, thnx Bender!! I been meaning to PM u and let u know I got it. Just slipped my mind. Nice skid man!! time to put it on and beat it up a little. Thnx for a great deal on a great skid.
kllrbee is offline
post #6 of 21 Old 11-03-2010, 08:35 AM
purplepig
Can I see pics of the UCF engine skid mounted to the stock TC skid? Mine doesn't look like it is going to fit well.
purplepig is offline
post #7 of 21 Old 11-03-2010, 09:42 AM
biffgnar
biffgnar's Avatar
Maybe look at this thread: http://www.jeepforum.com/forum/f9/uc...ifold-1085303/
That was my neighbor. As described in thread he had to do a little messing around but ended up nice.
biffgnar is online now
post #8 of 21 Old 11-03-2010, 10:53 AM
purplepig
Thanks for the link biffgnar. Mine setup doesn't look the same, but maybe I can get responses from others in that thread with the same setup.
post #9 of 21 Old 11-03-2010, 10:27 PM Thread Starter
kllrbee
Hey PP,
Mine fits exactly like the one in the pics.
Stock TC, no drop.
Like someone else said, bolt up the brackets, (might sound stupid, but make sure brackets are on there right), hold up the skid with a jack or something and push/pull/manuever it to exactly where you want it to bolt up to the TC skid. It took a little while for me to get it perfect. Mark, drill, bolt and you should be good to go.
Mine is also hitting the exhaust pipe so Im gonna need to do sme cutoff work. I dont really think it would hurt the pipe, but its kind o annoying to listen to. so I would recomend doing that before you bolt it up.
The skid is pimp so I hope you can get it right, cuz if its possible to love a skid, you will love this one.
Good luck.
kllrbee is offline
post #10 of 21 Old 11-07-2010, 06:54 PM
purplepig
This is what I am working with. What do I do?
I can't move it forward any further.
post #11 of 21 Old 11-07-2010, 07:36 PM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
You need to move it WAY farther forward. I just installed that skid and I drilled into the very front of the skid. Give me a minute and I'll get you pics.
DINOCAVE is offline
post #12 of 21 Old 11-07-2010, 07:42 PM
purplepig
If I move it forward it will hit the exhaust.? Does it go under below the exhaust?
post #13 of 21 Old 11-07-2010, 07:43 PM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Here is how mine is mated to the transmission skid.
DINOCAVE is offline
post #14 of 21 Old 11-07-2010, 07:46 PM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
Here is a photo from the UCF web site. This was the only thing I used as directions, since mine didn't come with any. I don't think any of them do. Pay VERY close attention to how the brackets are installed under the motor mount as well as which side the mounting bars go, both on the skid and on the mounts.
Once I installed everything up front to match this photo EXACTLY, the back just lifted right into place (with me pushing a bit). I drilled two holes, and BAM! Done.
DINOCAVE is offline
post #15 of 21 Old 11-07-2010, 07:49 PM
del_TJ
You want to get the lip of the engine skid just in front of the exhaust. CPT Jeep beat me to it.
del_TJ is offline
engine skid , UFC , install
supporting engine/transmission during skid install Flipside TJ Wrangler Technical Forum 8 06-17-2010 01:17 PM
Install issue with Skid Row engine skid gaTJgal TJ Wrangler Technical Forum 35 10-25-2009 05:50 PM
Engine Skid Install Trombino TJ Wrangler Technical Forum 4 07-23-2006 05:57 PM
Easiest To Install Engine Skid Plate?? Suggestions 97tj4me TJ Wrangler Technical Forum 7 07-12-2005 06:46 AM
