UCF Deep-Cover Skid Plate System - Page 9 - JeepForum.com
post #121 of 136 Old 12-18-2012, 02:11 PM
Ironhead
Originally Posted by GMBNT42 View Post
And thats wut matters....the 241 works best for your style of wheeling...all the power to ya....but imo with that 241.....go with a 1.25" bl and 1.5" mml if u still can....just better suited overall.....im changing out my 1" mml and bl for a 1.5" mml and a 1.5" bl if i can find a good one.....just a better solutuon for the ucf and savvy high tuck skids
hmmm, wonder why savvy incorporates a 1" mml into their skid. you should go tell them your theory. let em know they are doing it wrong
Ironhead is offline
post #122 of 136 Old 12-18-2012, 02:22 PM
biffgnar
biffgnar's Avatar
He'll just add it to the list of things he thinks are wrong with UA.
Romney in 2020!
biffgnar is offline
post #123 of 136 Old 12-18-2012, 02:27 PM
GMBNT42
Just because its savvy doesnt mean its best.....with 1" mml the tail end of the drivetrain still sits up higher in relation to the front vs stock...a 1.5" mml gets it closer to stock level. And adding a 1.5" bl gives a bit better tub clearance.....that extra .25-.5" does make a difference.
GMBNT42 is offline
post #124 of 136 Old 12-18-2012, 02:32 PM
Ironhead
Yep, can't wait for his products to hit the market. It's gonna revolutionize the offroad community
Ironhead is offline
post #125 of 136 Old 12-18-2012, 02:36 PM
Ironhead
So that .25" of tub clearance is necessary for your np231 and 6sp, yet my larger 241 and 42rle fit just fine? Why don't you give us more advice on upgrades you have yet to install
Ironhead is offline
post #126 of 136 Old 12-18-2012, 02:39 PM
GMBNT42
It can be improved on just like countless prefabbed products on market. ;-)
GMBNT42 is offline
post #127 of 136 Old 12-18-2012, 02:47 PM
GMBNT42
I want the extra .5" clearance for a few reasons...one being so the fan shroud not needing to be messed with.....two, so my leather shift boot does pull on console when in 2,4,6th gears......and 3rd to give more clearance for the drivetrain to tub clearance and mods im going to implement to the shock mounts on tge frame.
GMBNT42 is offline
post #128 of 136 Old 12-18-2012, 02:52 PM
biffgnar
biffgnar's Avatar
We've talked before about the type of changes that are non-replicable in a production product v. custom fab. I don't see how height of ML and/or MML is one of those things.
Romney in 2020!
biffgnar is offline
post #129 of 136 Old 12-18-2012, 03:02 PM
TURBevO8
I wish I wouldve known this before I did my MML. I guess I just always read nobody had an issue with this combo which is why I posted it in this thread so others now know. I would do the 1.5" if I knew 9 mos ago what I know now. But now that I am done, I am cool with it the way it is. Anything aftermarket should be expected to be modified. If not, bonus! Good info though so thanks for posting. May help others.
EDIT: Just read back through this page...lol. Can't we all just get along?
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #130 of 136 Old 12-18-2012, 03:25 PM
GMBNT42
Well Brown Dog already makes a good 1.5" MML, and if Savvy can make a 1.25" BL, no reason why they can't come up with one that's a .25" taller. The engineering is already there. But a slightly taller BL makes ALOT of sense for a number of differing reasons.
And anything that can be custom fabbed, can be replicated and mass produced.
GMBNT42 is offline
post #131 of 136 Old 12-18-2012, 03:41 PM
Ironhead
like what?
Ironhead is offline
post #132 of 136 Old 12-18-2012, 03:49 PM
GMBNT42
like what?
Read previous post
GMBNT42 is offline
post #133 of 136 Old 12-18-2012, 03:51 PM
Ironhead
i would ask you to do the same.
Ironhead is offline
post #134 of 136 Old 12-18-2012, 04:56 PM
biffgnar
biffgnar's Avatar
But Savvy wasn't looking to be in the MML business. They were in the business of building a tummy tuck system. They built what they believed worked best with their system. They just sell the component parts as an extra. For their system they believe the design they offer is best. If you want to second guess what's best for their system I think people are going to be skeptical of your opinion. If you instead are saying that what they offer doesn't work for the custom skid you will fab then more power to you.
And your last statement is just silly. Even if a product can be standardized, there are countless products that the pricing doesn't work for on a production basis. And as we've discussed in prior threads there are some things that just can't be standardized. I don't think you're that naive, so I assume you're just being argumentative which is pretty pointless in this thread about UCF products.
Romney in 2020!
biffgnar is offline
post #135 of 136 Old 12-18-2012, 06:48 PM
GMBNT42
I never said Saavy was looking to be in the MML business. And they don't need to be either. A fantastic 1.5" MML is already available. And regardless if you run a Savvy UA system or UCF system, a 1.5" MML with a 1.5" BL works better. Gives a bit more clearance between the tub and drivetrain(Esp. the 241), and levels out the drivetrain closer to stock so the rear TC output doesn't angle so far upwards.
GMBNT42 is offline
ucf , skid plate , armor , protection , under cover fabworks
Riddler diff cover or Warn diff skid plate? fduncan TJ Wrangler Technical Forum 16 05-23-2010 05:48 AM
Poly Performance Skid Plate System HungryHeart JK Wrangler Technical Forum 0 12-30-2009 08:54 PM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 08:46 AM
32RH 3 Speed Automatic Deep Tranny pan skid plate harpo1 TJ Wrangler Technical Forum 13 12-01-2008 08:27 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 03:51 PM
