UCF Deep-Cover Skid Plate System - Page 2 - JeepForum.com
post #16 of 136 Old 07-14-2010, 10:52 AM
roundlitefan
I have a 1.25" BL. No MML. 3.25" SL (that's sagged to ~2")
04 Rubicon.
If I get the ultra high clearance skid, will I need to purchase a CV drive shaft as well? I realize all Jeeps are different, but it would be nice to know prior to ordering.
Thanks
It is a Rubi with a fixed output yoke, doesn't it come with a double Cardan rear driveshaft?
roundlitefan is offline
post #17 of 136 Old 07-14-2010, 11:02 AM
RubiconRazorbac
RubiconRazorbac's Avatar
No. Even though the t-case is a fixed yoke, the DS from the factory is just a regular old DS with a single u-joint at each end.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #18 of 136 Old 07-14-2010, 11:03 AM Thread Starter
undercoverfab
Vendor
undercoverfab's Avatar
No, it's a standard single joint shaft.
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #19 of 136 Old 07-14-2010, 11:50 AM
Imped
Imped's Avatar
To answer your question, yes, you would need to get a double cardan shaft and adjustable uppers at a minimum to tilt the pinion up.
OlllllllO
IndyORV
Imped is offline
post #20 of 136 Old 07-14-2010, 12:50 PM
roundlitefan
Hmm, never knew that, just figured all the Rubi's came with a Cv driveshaft.
Guess it makes sense in retrospect, since the CA's are the same as the Sport and X models, and the axles don't have the brackets aligned differently AFAIK.
Just never thought about it.
post #21 of 136 Old 07-14-2010, 01:43 PM
rob78
Thanks.
Ultimate goal is to remove the godawful transfer case drop (1" "pucks").
Am going to install a 1" MML. Check driveshaft angle and determine if I need to install washers.
I'd also like to put in a 4" spring up front to remove rake.
I'm hoping to do this all at once (including put in the UCF skid). Looks like I'll need a CV shaft and adjustable rear uppers too.
why can't anything just be simple?
rob78 is offline
post #22 of 136 Old 07-14-2010, 06:23 PM
elephantrider
Originally Posted by zachbh View Post
That's great to know. 1/4" or 3/8"?
1/4" aluminum
elephantrider is offline
post #23 of 136 Old 07-14-2010, 07:11 PM
2006_Sport
Giving Savvy some great competition. This looks like an awesome product.
2006_Sport is offline
post #24 of 136 Old 07-14-2010, 08:46 PM
Mattman
I have the 1/4 inch aluminum transfer case skid with Skid Row engine skid and it is TOUGH! I beat it hard over the 4th of July and it took anything that i could throw at it. Highly recommended.
Mattman is offline
post #25 of 136 Old 07-15-2010, 08:32 AM
rob78
Good to know.
I've got to start getting parts together.
rob78 is offline
post #26 of 136 Old 07-15-2010, 01:55 PM
rob78
Anybody know if the 3/8" skid is a worthwhile purchase or would 1/4" suffice for moderate wheeling (trails, some mild rocks)?
rob78 is offline
post #27 of 136 Old 07-16-2010, 08:16 AM Thread Starter
undercoverfab
Vendor
I reduced the price of the the Deep-Cover System by 5%.
Attached you will see the cost of the system optioned all the way out with a 3/8" thick 6061-T651 aluminum transfer case skid, 1/4" thick 6061-T651 aluminum engine skid, LOPRO mount, 1" body lift and MML.
You can save an additional 10% with the "jeepforum.com" discount code. That brings the total cost of this system optioned all the way out to just $859.
Thanks,
Matt Walton
(334) 446-3821
Check us out on
post #28 of 136 Old 07-16-2010, 08:56 AM
rob78
Thanks,
wow
rob78 is offline
post #29 of 136 Old 07-16-2010, 10:56 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Will the engine skid work with the TNT high. Clearance belly pan?
Recoil is offline
post #30 of 136 Old 07-16-2010, 11:16 AM Thread Starter
undercoverfab
Vendor
It will work with other skids that are shaped similarly to the factory skid or my skids. I'm not familiar with their product. Send me a picture at: matt@undercoverfab.com and I will take a look.
Thanks,
Matt Walton
(334) 446-3821
Check us out on
ucf , skid plate , armor , protection , under cover fabworks
Riddler diff cover or Warn diff skid plate? fduncan TJ Wrangler Technical Forum 16 05-23-2010 04:48 AM
Poly Performance Skid Plate System HungryHeart JK Wrangler Technical Forum 0 12-30-2009 07:54 PM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 07:46 AM
32RH 3 Speed Automatic Deep Tranny pan skid plate harpo1 TJ Wrangler Technical Forum 13 12-01-2008 07:27 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
