UCF Deep-Cover Skid Plate System - Page 10 - JeepForum.com
post #136 of 136 Old 12-19-2012, 08:37 AM
GMBNT42
Actually, that Rokmen 1/2" spacer kit is perfect. Its cupped and designed to sit between the metal bushing sleeve/retainer and the tub. And uses hard pressed cups for the grill snubbers up front bypassing those nipple retainers that break off easy. Works perfectly for stand alone 1" BL's like the ones from Daystar, Prothane etc.....Just ordered up a set of them from Rokmen and a new BrownDog 1.5" MML. And am in the process of modding the M.O.R.E. steering shaft riser to sit a half inch higher as well.
All problems solved(Rear DS angle improved,shift boot tension, engine fan better centered in shroud, exhaust hanger etc).
GMBNT42 is offline
ucf , skid plate , armor , protection , under cover fabworks
Riddler diff cover or Warn diff skid plate? fduncan TJ Wrangler Technical Forum 16 05-23-2010 04:48 AM
Poly Performance Skid Plate System HungryHeart JK Wrangler Technical Forum 0 12-30-2009 07:54 PM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 07:46 AM
32RH 3 Speed Automatic Deep Tranny pan skid plate harpo1 TJ Wrangler Technical Forum 13 12-01-2008 07:27 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
