UCF Deep-Cover Skid Plate System - JeepForum.com
post #1 of 136 Old 07-14-2010, 08:03 AM Thread Starter
undercoverfab
Vendor
undercoverfab's Avatar
Our Deep-Cover Skid Plate System is the only custom configurable skid plate system on the market. It provides the flexibility of design to allow for the wheeler with a modest budget to protect the most vulnerable of locations on the vehicle. It will also provide the options desired by the most hard-core of rock crawlers to purchase the strongest, thickest undercarriage protection available on the market.
Under Cover Fabworks, LLC - UCF Deep-Cover Skid Plate System
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #2 of 136 Old 07-14-2010, 08:16 AM
Fropleyqk
Fropleyqk's Avatar
Is that $409 for the skid plate and engine skid?
Fropleyqk is offline
post #3 of 136 Old 07-14-2010, 08:20 AM Thread Starter
undercoverfab
Vendor
That's correct.
Matt Walton
(334) 446-3821
Check us out on
post #4 of 136 Old 07-14-2010, 08:21 AM
GotLime
Can you give us approximate weights for the different thicknesses and materials?
GotLime is offline
post #5 of 136 Old 07-14-2010, 08:52 AM Thread Starter
undercoverfab
Vendor
I just added the weights. Thanks for the suggestion.
Matt Walton
(334) 446-3821
Check us out on
post #6 of 136 Old 07-14-2010, 09:17 AM
rob78
Looks like an excellent product.
Your pricing is outstanding. 1/4" thick 6061 aluminum engine/trans skid for ~$630!!
rob78 is offline
post #7 of 136 Old 07-14-2010, 09:24 AM
Fropleyqk
Fropleyqk's Avatar
Originally Posted by undercoverfab View Post
That's correct.
awesome.
post #8 of 136 Old 07-14-2010, 09:42 AM
rastadog
rastadog's Avatar
...potentially dumb question but will this fit a 2001 with the 3 speed auto? I've already got a body lift and MML. Will the high clearance model work? (assuming I have to get a SYE and adjustable rear upper control arms.)
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #9 of 136 Old 07-14-2010, 09:46 AM
elephantrider
the aluminum skids are rock solid fellas. i run both
the belly and engine skid. excellent coverage and
great fit.
elephantrider is offline
post #10 of 136 Old 07-14-2010, 09:48 AM
zachbh
great fit.
That's great to know. 1/4" or 3/8"?
Looks like you got a great product here, it's always good to have competition in the aluminum t-case skid/engine skid area . I wish I could pony up some bills and get the whole set. Next summer maybe?
zachbh is offline
post #11 of 136 Old 07-14-2010, 09:56 AM Thread Starter
undercoverfab
Vendor
If you already have the body lift you can use the 1" deep Ultra High-Clearance skid with your setup. The early TJ skid will work for both auto and 5-speed transmissions.
Thanks,
Matt Walton
(334) 446-3821
Check us out on
post #12 of 136 Old 07-14-2010, 10:54 AM
yellowjesus
Is there any difference in hight between the no body lift transfer case skid and the factory one? I really want the 1" deep but then i have to wait for an sye and cv first. I just received my early tj engine skid from you, it looks really beefy and I can not wait to go rub it on some rocks.
yellowjesus is offline
post #13 of 136 Old 07-14-2010, 10:58 AM Thread Starter
undercoverfab
Vendor
Yes, the No Body-Lift skids are about 1 1/2" thinner in profile than the factory skid.
Thanks,
Matt Walton
(334) 446-3821
Check us out on
post #14 of 136 Old 07-14-2010, 11:38 AM
rob78
I have a 1.25" BL. No MML. 3.25" SL (that's sagged to ~2")
04 Rubicon.
If I get the ultra high clearance skid, will I need to purchase a CV drive shaft as well? I realize all Jeeps are different, but it would be nice to know prior to ordering.
Thanks
rob78 is offline
post #15 of 136 Old 07-14-2010, 11:45 AM Thread Starter
undercoverfab
Vendor
04 Rubicon.
Thanks
Yes, I would think you would need the driveshaft.
Matt Walton
(334) 446-3821
Check us out on
ucf , skid plate , armor , protection , under cover fabworks
Riddler diff cover or Warn diff skid plate? fduncan TJ Wrangler Technical Forum 16 05-23-2010 05:48 AM
Poly Performance Skid Plate System HungryHeart JK Wrangler Technical Forum 0 12-30-2009 08:54 PM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 08:46 AM
32RH 3 Speed Automatic Deep Tranny pan skid plate harpo1 TJ Wrangler Technical Forum 13 12-01-2008 08:27 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 03:51 PM
