UCF Deep Cover Install Prep - Engine/Belly Skid, LoPro Mount - JeepForum.com
post #1 of 3 Old 08-25-2010, 07:39 AM Thread Starter
UncleWilson
UncleWilson's Avatar
I'm looking for past experience and guidance during the install
Okay, so this weekend I'm planning on installing the UCF Deep Cover Skid System and I'd like to have everything I need at my finger tips prior to getting started. The parts I have:
Ultra High Clearance Skid
Engine Skid with Brackets
LoPro Mount
Rubi Pump Mount Bracket
Extra Tools:
2 Floor Jacks
Angle Grinder
Wrenches
Loctite
Anti-Seaze
4 Jack Stand
I've also got the instructions for the LoPro Mount:
http://undercoverfab.com/attachment.php?id_attachment=2
What I'm looking for is (in the way of wisdom):
What extra hardware do I need to buy?
Are there any tips or trick you've learned?
I appreciate any help I can get.
-Thank you
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #2 of 3 Old 08-25-2010, 10:25 AM
bobthetj03
I have installed the low pro mount, but still have the factory skid, so some of my experience might apply. In the instructions it says to cut the exhaust holder bracket that is part of the trany mount. Do lots of test fitting first and don't cut that bracket until you first check the fit. You may not need to cut that bracket. I had to grind some areas of the new mount cause I had interference with the factory skid, but you may be ok there since your installing the UCF skid.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #3 of 3 Old 08-25-2010, 11:45 AM
AstroZombie
Here's a thread on what I did to help the install of my lo-pro mount. Things didn't line up right for me and welding studs in place helped considerably in getting everything where it needed to be.
I also had to clearance my tub around the T-case linkage where the brackets mount to the floor. I took the linkage drop bracket that I got with my JKS BL, and flipped it upside down to use it reverse of which it was intended. (Raising the linkage pivot to keep the linkage square) I had a pain in the butt time getting my linkage to work right and even considered the Novak cable to eliminate the binding issues. Flipping the bracket helped but in the future I may still go the Novak route.
http://www.jeepforum.com/forum/f9/uc...esign-1050782/
2004 Black Rubicon. Locker mod and a few other things...
USN Jeep Club Hull # 199
AstroZombie is offline
belly skid , engine skid , install , skid , ucf
UCF Deep-Cover Skid Plate System undercoverfab TJ Wrangler Technical Forum 135 12-19-2012 08:37 AM
UCF Deep-Cover Skid Plate System undercoverfab YJ Wrangler Technical Forum 27 01-16-2011 12:07 PM
Under Cover Fabworks Deep-Cover skid? Dirt22 TJ Wrangler Technical Forum 0 08-23-2010 09:21 AM
Teraflex Belly Up and Skid Row Engine Skid Compatibility jeepteejay TJ Wrangler Technical Forum 1 11-25-2009 08:24 PM
trans mount for belly up skid? timritchieblue TJ Wrangler Technical Forum 0 06-06-2009 07:21 PM
