UCF Belly Pan Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > UCF Belly Pan Questions
Spartan Lockers FREE SHIPPING Excellent PricesRough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free Shipping
Unread 05-30-2012, 10:37 AM   #1
RubiconChris
I plan on ordering a 1/4 in UCF transfer case skid, Rubi pump mount and a lo pro tranny mount. I already have a 1 1/4 BL, MML and Clayton adjustable control arms with 4 inches of lift. I want to know if I can get away with using my stock driveshaft for a couple weeks. And what else am I`m gonna have to deal with. This is going on a 05 Rubicon with a 6 spd manual trans.
35 inch MTR Kevs, Clayton short arms, Bilstein 5100`s, Currie 4" springs, UCF ultra hi clearance skid, UCF Lo pro tranny mount, Brown Dog MML, RC 1.25 BL, Rustys steering, Warn 9.5i, Rugged Ridge rock bumpers, Bestop tire carrier, Tatton rear driveshaft, Ten factory front and rear alloy`s, Synergy ball joints, Currie front trac bar, JKS discos
RubiconChris is offline   Reply With Quote
Unread 05-30-2012, 10:51 AM   #2
Fropleyqk
Fropleyqk's Avatar
Which UCF skid?
Yes or no. Different Jeeps are... different. You may be able to get away without a CV shaft, you may not. If you have vibes drop the skid down until you can afford the DS and rotate the pinion back. I'd pull the trigger on the DS now but thats just me.
Fropleyqk is offline   Reply With Quote
Unread 05-30-2012, 10:51 AM   #3
joshr1987
4"s of lift is really pushing it with a belly up. I would Probablywait until I had a ds in hand. Maybe someone here has done it though... Good luck with it man!
Another Stretched TJ in the works...
My Build Dubbed "Flo"
joshr1987 is online now   Reply With Quote
Unread 05-30-2012, 10:53 AM   #4
joshr1987
Originally Posted by Fropleyqk
Which UCF skid?
Thats a good point, I just assumed it is an uhc skid.
Unread 05-30-2012, 10:56 AM   #5
biffgnar
biffgnar's Avatar
You need a new driveshaft already with 4" of lift. A couple more inches from a TT and keeping that shaft not a good idea. If you want to do it pull rear driveshaft and drive in front wheel drive till able to do right.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
Unread 05-30-2012, 10:57 AM   #6
MotoSoul
Just add dump truck
MotoSoul's Avatar
Which height skid are you going with? I am going to bet that with pretty much any of the options the angle will be too much for the stocker. I would plan on getting a new shifter cable for the transfer case.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline   Reply With Quote
Unread 05-30-2012, 12:05 PM   #7
Imped
Balls
Imped's Avatar
No.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 05-30-2012, 12:44 PM   #8
SideshowBob024
Yeah, there is no way the factory DS will work. It may spin the rears until the axle moves, then it's gonna fall out.
SideshowBob024 is offline   Reply With Quote
Unread 05-30-2012, 09:32 PM   #9
RubiconChris
How can the driveshaft fall out if its bolted to the transfer case? I have a Rubicon. My stock belly pan is pushed so far up that I dont think the Under Cover Fab skid plate is much higher and wouldnt change my driveshaft angle that much esspecially with the lo pro mount. As far as shifter cable, I have a 6 spd manual trans.
Unread 05-30-2012, 09:42 PM   #10
alex211
Now ****in way it would work, it's bound up at ride height with a lo pro, uhc skid, 3" springs, and the pinion tilted up for a cv shaft.
03 TJ
Build thread - http://www.jeepforum.com/forum/f9/my-rubicon-build-thread-slow-1255392/
alex211 is offline   Reply With Quote
Unread 05-30-2012, 10:06 PM   #11
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
...but that's not a CV shaft.
Unlimited04 is offline   Reply With Quote
Unread 05-31-2012, 07:34 AM   #12
RubiconChris
Thanks, I do see what your talking about. I thought the Lo Pro mount would drop the t-case in the belly pan more and help that.
Unread 05-31-2012, 07:54 AM   #13
MotoSoul
Just add dump truck
MotoSoul's Avatar
I wasn't talking about the transmission. You are going to need to address the transfer case shifting as the stock linkage doesn't work to well when moved around.
http://www.novak-adapt.com/catalog/kit_sk2xr.htm
http://www.advanceadapters.com/produ...1--715543-241/
Unread 05-31-2012, 09:14 AM   #14
RubiconChris
Dam, all this is starting to add up! Maybe I should get the driveshaft 1st.
Unread 05-31-2012, 09:39 AM   #15
DanZ51
I recently did the Original Extra Clearance skid (w/Lo-Pro trans mount and MML) from UCF on my "no-lift" TJ Rubicon. And I still got vibes. Adjustable control arms helped quite a bit in making things parallel but still couldn't stop the vibes.
With 4" of lift on a TJ (LJs got more driveshaft to work with) there's no way you're gonna make a TT work with out a CV (DC) drive shaft. For a temporary fix go front wheel drive, or some big *** spacers to lower the transfer back down.
Yes, it does. I tried and failed, but I knew I may have to dig a little deeper in my pocket from the start. At least the Tom Wood driveshaft was only $305 (for the Rubicon).
"I will always be an American Soldier"
DanZ51 is offline   Reply With Quote
