U-POL Raptor sanding question - JeepForum.com
post #1 of 2 Old 08-11-2009, 07:53 PM Thread Starter
justin102
OK, today i started sanding the tub....
i see the pics here and there of progress and of course you want to make sure you sand enough. I used 120 grit with a air sander and tight spots were done by hand.
-just making it dull and scratchy should be enough correct? (I did go to metal on some parts thanks to the power of air tools)
-How long should I allow for drying? I can take my motorcycle to work on Friday, just want to spray Friday night and be able to get to work on Monday with at least my driver seat back in.
**Any other tips?
Thanks!
"A jeep is like a fine woman, they both suck you dry of money"
justin102 is offline
post #2 of 2 Old 08-11-2009, 08:16 PM
Wloch248
dull and scratchy should be fine. just make sure you clean ALL of the dust out.
2 full days as long as it isn't in 100% humidity hot weather you should be good to put just the drivers seat back in. but longer than that to fully cure.
good luck!
Wloch248 is offline
Question for all who have used Raptor liner SE_Alaskan Wrangler General Discussion 0 07-29-2009 09:44 AM
Raptor question - carpet any good options? jc45840 TJ Wrangler Technical Forum 6 07-12-2009 05:59 PM
U pol raptor question Wrangler_91 Wrangler General Discussion 1 04-05-2009 10:17 PM
sanding? 91YJ4X4 YJ Wrangler Technical Forum 1 07-08-2007 09:26 PM
Sanding a YJ. Wolverineprez YJ Wrangler Technical Forum 10 05-23-2004 09:52 PM
