U-pol Raptor question - JeepForum.com
post #1 of 4 Old 07-02-2010, 06:56 PM Thread Starter
buckeye_1
So I spent all day preparing the jeep for U-pol. Stipped out the tub, sanded it, rinsed it out, and wiped the whole thing down with acetone. Do I need to sand the whole thing down to bare metal or just enough to rough up and dull out the paint? I think I just got it dull with my first jeep, but that's been a good while. I didn't have problems with the first one, but I want to make sure it's right before I spray it in the morning.
buckeye_1 is offline
post #2 of 4 Old 07-02-2010, 08:24 PM
jdub36
Dont take it down to bare metal. You just want to take off the clear coat. If you have any spots that have bare metal showing you might want to hit them with primer. After you wash it off it should have a dull finish on it as long as it is not shiny you should be good to go.
jw
jdub36 is offline
post #3 of 4 Old 07-02-2010, 08:56 PM
schu
i scuffed mine with a wire brush drill attachment then sprayed with self etching primer. Did this with both my tub and bumpers, tub has been pretty good besides in a couple hard to reach corners and throwing the seat in and out, easy to touch up though. Bumpers have so good spots taken out but rocks will do that and the pealing hasn't continued out from the chips
schu is offline
post #4 of 4 Old 07-03-2010, 04:48 AM Thread Starter
buckeye_1
OK...thanks for the replies. I probably hit up a couple spots with primer and start spraying then.
u-pol raptor , liner , spray liner , tj
Raptor U-Pol question Goobersbro TJ Wrangler Technical Forum 6 03-15-2010 09:47 PM
U-POL Raptor sanding question justin102 TJ Wrangler Technical Forum 1 08-11-2009 08:16 PM
Question for all who have used Raptor liner SE_Alaskan Wrangler General Discussion 0 07-29-2009 09:44 AM
Raptor question - carpet any good options? jc45840 TJ Wrangler Technical Forum 6 07-12-2009 05:59 PM
U pol raptor question Wrangler_91 Wrangler General Discussion 1 04-05-2009 10:17 PM
