u joints front drive shaft - JeepForum.com
post #1 of 11 Old 02-25-2008, 07:04 PM Thread Starter
mlb2003
so i changed out the ujoints in the front ds and they still are making the sparrow noise. what would cuase this? thanks
Mike
35x12.5x15" tires, 2" coil spring lift, 4" X series Rough Country Lift, 7" Rugged Ridge Fender Flares, hanson 60" bumper front with prerunner and fender bars, LOD extreme rear bumper/tire carrier, high lift, Delta 7" headlight replacements, Warn 9.5ti w/synthetic line, hella black magic lights, sye/cv ds, D30/44 with arb lockers, tera disc brakes, 4.88 gears and shafts
mlb2003 is offline
post #2 of 11 Old 02-25-2008, 07:15 PM
daveg13
daveg13's Avatar
Did you also replace the centering ball?
daveg13 is offline
post #3 of 11 Old 02-25-2008, 07:19 PM
csaw44
the angry sparrow noise comes from the cv ball on the t case end of the front driveshaft. you should pack it with grease when you replace the u-joints. I drilled and tapped mine for a grease fitting so now when the bird sings,I can just shoot in some lube
csaw44 is offline
post #4 of 11 Old 02-25-2008, 07:46 PM Thread Starter
mlb2003
no i didnt replace that. whats the cv ball look like? is that the t lookin thing that takes a little pressure to push down when the 2nd u joint (closest to the t case)
mlb2003 is offline
post #5 of 11 Old 02-25-2008, 07:53 PM Thread Starter
mlb2003
also when i was buying u joints, i bought the u joints for non command trac (thinking the jeep doesnt have it) they didnt fit. the ones for command trac did fit. am i going crazy or do the tj's have command trac?
mlb2003 is offline
post #6 of 11 Old 02-25-2008, 08:19 PM
otisdog
2008 WK
Everything you need to know including part #'s.
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 11 Old 02-25-2008, 08:37 PM Thread Starter
mlb2003
thanks for the info! i forgot about stu's site
mlb2003 is offline
post #8 of 11 Old 02-25-2008, 09:26 PM
Chris_
The auto parts stores carry a ball seat kit, but it's a lot easier to buy that whole centering piece. I think the price difference was about $7. Save yourself the headache and get the centering piece, rather than the ball kit.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #9 of 11 Old 02-26-2008, 07:22 PM Thread Starter
mlb2003
thanks for the help.
mlb2003 is offline
post #10 of 11 Old 02-26-2008, 07:33 PM
carpekd
If you don't want to tap it for a grease fitting, you can buy a needle tip for your grease gun to grease it. It's already set up for that.
carpekd is offline
post #11 of 11 Old 02-26-2008, 08:49 PM Thread Starter
mlb2003
yeah i already intended on buyin the fitting for the grease gun
mlb2003 is offline
no zerks on front drive shaft U joints-now what van1 TJ Wrangler Technical Forum 2 12-19-2009 06:32 PM
Drive shaft U joints bombero590 TJ Wrangler Technical Forum 2 08-02-2008 08:22 PM
Front drive shaft u-joints jeep jake TJ Wrangler Technical Forum 3 10-14-2005 05:33 PM
Changing U joints in front drive shaft...HELP!! KY TJ TJ Wrangler Technical Forum 7 01-26-2005 05:38 AM
Drive shaft U-joints TwinYJ9 YJ Wrangler Technical Forum 1 10-06-2004 04:18 PM
