U-joint question - JeepForum.com
post #1 of 3 Old 08-20-2010, 09:57 PM Thread Starter
Ryman12
U-joint question
Hey everybody, my jeep has been acting up recently and I wanted to clear a few things up before I went ahead and ordered new parts.
I let my buddy drive my jeep today and he cranked the steering wheel all the way. Now whenever I make a mild or full turn there will be severe steering wheel wobble and when backing out it can even bring my car to a stop (usually I just give it a little gas and coast out of a parking spot). So I did some research and I came to the conclusion that my front end u-joints are probably shot. After 120k miles I think the stock ones are ready to croak. But I need some advice on what type to get. I hear spicer is a good brand, but what model? The 760? Also, could bad u-joints contribute to sloppy steering?
Thanks in advance for the help!
BTW I have dana 44 axles and its my daily driver.
Ryman12 is offline
post #2 of 3 Old 08-20-2010, 10:39 PM
oakmckinley
A bad U Joint won't affect steering, I would crawl under and while someone is turning the wheel look for anything suspect in the steering linkages.
My 99TJ has the original U joints and has 145xxx, so don't necessarily assume they're worn out.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 3 Old 08-20-2010, 11:00 PM Thread Starter
Ryman12
Hmmm thanks for the advice. I actually had a buddy turn steering wheel while I watched the steering components and it seemed tight all the way to the gear-box. Ill have to take a look underneath next time. However, I am 90% sure the u-joints are bad due to the wobble when I make turns. I was just curious if that could contribute to the slop so-to-speak.
Ryman12 is offline
u joint , u-joint , axle , replacement , tj , wrangler , steering
u-joint question BrianI TJ Wrangler Technical Forum 11 08-10-2009 12:35 PM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 10:28 AM
U joint question frumpy YJ Wrangler Technical Forum 13 06-21-2008 07:22 AM
CV Joint question. Todd4a TJ Wrangler Technical Forum 4 05-20-2008 08:10 AM
U- Joint Question seanw YJ Wrangler Technical Forum 4 04-11-2003 06:50 AM
