u bolt driveshaft yoke - JeepForum.com
post #1 of 8 Old 01-04-2012, 04:56 PM Thread Starter
leaf777
If I buy an aftermarket axle with a u-bolt yoke, will my aftermarket DC driveshaft work?
leaf777 is offline
post #2 of 8 Old 01-04-2012, 06:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes, if it is made for the particular u-joint size on your driveshaft.
Be wary with those u-bolts though, it is VERY easy to overtighten them and damage the u-joint's needle bearings underneath the bearing cap. The standard u-joint straps are more than strong enough, don't consider the u-bolts to be a good idea as an upgrade if they are simply an option for your axle.
Jerry Bransford is offline
post #3 of 8 Old 01-04-2012, 06:31 PM Thread Starter
leaf777
I'm looking at the G2 axle, it comes with u bolts. It says driveshaft mods may be required, just trying to think of what may need to be done.
leaf777 is offline
post #4 of 8 Old 01-04-2012, 06:33 PM
biffgnar
biffgnar's Avatar
Driveshaft length depending on what axle you are taking out?
Romney in 2020!
biffgnar is offline
post #5 of 8 Old 01-04-2012, 06:43 PM Thread Starter
leaf777
I will be replacing a 44 with a SYE and DC shaft. I'm looking at the G2 with 4.56 and OX locker.
leaf777 is offline
post #6 of 8 Old 01-04-2012, 06:45 PM
biffgnar
biffgnar's Avatar
A G2 44? Driveshaft should bolt right up on that swap.
Romney in 2020!
biffgnar is offline
post #7 of 8 Old 01-04-2012, 06:55 PM Thread Starter
leaf777
Would $1000 be a resonable asking price for both my d30 & d44 with 3.73?
leaf777 is offline
post #8 of 8 Old 01-04-2012, 07:03 PM
26679cj5
you would be close to getting that just out of the d44 so i think its fair.
26679cj5 is offline
U-bolt style vs. strap style (driveshaft to yoke u-joint) I8AHUMR YJ Wrangler Technical Forum 27 12-08-2014 02:55 PM
broken driveshaft yoke kojak70 YJ Wrangler Technical Forum 9 06-16-2010 05:28 PM
Front Driveshaft/Yoke Bhelliom TJ Wrangler Technical Forum 13 08-16-2007 06:50 AM
Front Driveshaft Yoke; Same for 4 and 6? Woodyhfd TJ Wrangler Technical Forum 1 11-28-2006 09:37 AM
Busted Bolt on Front Driveshaft Yoke! Raxmar TJ Wrangler Technical Forum 7 12-01-2005 09:32 AM
