Type of grease! - JeepForum.com
post #1 of 22 Old 07-16-2013, 08:47 PM Thread Starter
homeboy1991
Type of grease!
Hello everyone I was wondering what brand and type of grease do you use on your suspension parts? I have the Currie arms and they are starting to creek little. I'm thinking the grease I use may be wrong for them. Thanks in advanced!
My TJ Build Thread -
homeboy1991 is offline
post #2 of 22 Old 07-16-2013, 10:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What grease do you use? The grease does two things: expels water and lubricates the joints.
Luck Favours The Prepared
Anticanman is offline
post #3 of 22 Old 07-17-2013, 11:57 AM Thread Starter
homeboy1991
If I remember correctly I'm using a synthetic grease from shell if I am correct. My Grandfather had a tube extra that he uses on his tractors.
post #4 of 22 Old 07-17-2013, 12:05 PM
Tonellin
red n tacky
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #5 of 22 Old 07-17-2013, 12:33 PM
clg82
"green grease" here.... http://www.greengrease.net/
clg82 is offline
post #6 of 22 Old 07-17-2013, 12:36 PM
freeskier93
How often are you greasing them? How are you greasing them (bolt zerks or housing zeros)?
Seems like from what I've seen greasing methods are all over the place with JJs and there's confusion about greasing through the housing or through the bolt. The best method I've seen is complete disassembly, clean every joint, and apply some high moly CV type grease.
freeskier93 is offline
post #7 of 22 Old 07-17-2013, 12:41 PM
clg82
didn't read the whole post I apologize, when I started getting some creeking coming out of my JJ, it turns out that I didn't have the bolt tight enought holding the control arm in place....make sure that they are as tight as you can get them....I retightened all of mine and thus far no more creeking.
clg82 is offline
post #8 of 22 Old 07-17-2013, 12:49 PM Thread Starter
homeboy1991
Yea, I tightened them up last night but they are still creaking a little. I had gone about 6 moths or more and they started it. I was thinking I would have to take them apart and rebuild them if they kept on creaking.
post #9 of 22 Old 07-17-2013, 03:14 PM
clg82
how long have you had them?
clg82 is offline
post #10 of 22 Old 07-17-2013, 03:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One thing to know about greasing Johnny Joints... the clearances inside are SO TIGHT that they don't readily take grease through the zerk fitting. I pretty much realize that to get them thoroughly greased that I'll have to take the joint apart & grease it internally by hand, then put it back together. Fortunately Johnny Joints don't usually require greasing all that often.
Jerry Bransford is offline
post #11 of 22 Old 07-18-2013, 07:10 AM Thread Starter
homeboy1991
I've had them for a year and a half now. Just recently started this creaking and I am pretty positive that it is coming from the front lowers. I may have to take them apart and make sure the joint is still okay. and clean and grease them.
post #12 of 22 Old 07-18-2013, 08:35 AM
chevellian
I agree with freeskier and Jerry. I just went through this with my one year old JJ's. Greasing them through the zerks is a real hit or miss thing (more miss than hit).
On all my JJ's the ball had no hole for the grease to get in from the greasable bolts, and even if they did it would still be a crap shoot on getting any grease between the ball and bushing. The grease zerk on the housing is a better bet, but still more miss than hit.
Pull the arms, take them apart, clean and grease them. Your joints are probably fine, mine were all very stiff and dry as a bone but the components were all fine. I paid particular attention in polishing the hardened ball. Currie makes a tool for taking the joints apart, but I managed with a long bolt, socket and washers in varying combinations to remove and install the components. You will also need a decent set of snap ring pliers.
Took me about sixteen hours to go through all sixteen joints and three tracbar joints, which are a little different (inner bushing is one piece). Not looking forward to doing this again.
When the only tool you have is a hammer, every problem starts looking like a nail.
chevellian is offline
post #13 of 22 Old 07-18-2013, 10:04 AM
AtomicDog
You might consider a penetrating dry lube that can be sprayed on. Something like Molybdenum Sulfide with an evaporating carrier.
Warranty and customer service won't matter if your equipment fails during a zombie attack.
Torture numbers long enough and they'll tell you what you want to hear.
cq cq KI4DOG
AtomicDog is offline
post #14 of 22 Old 07-18-2013, 12:52 PM
Ross
use a silicone grease. Petroleum based grease may break down rubber components faster.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #15 of 22 Old 07-18-2013, 02:24 PM
Jerry Bransford
Administrator
There is no rubber in the Currie Johnny Joints the OP has.
