type of differential fluid - JeepForum.com
post #1 of 6 Old 04-01-2009, 04:49 PM Thread Starter
cfordhockey23
Just got a '97 Wrangler and want to do a complete tune-up. Looked all over and wasn't able to find out what type of fluid it will take. Can anyone help?
cfordhockey23 is offline
post #2 of 6 Old 04-01-2009, 04:52 PM
wes19d
I use 80w90 in the front and 85w140 in the rear. If you dont do any towing or wheeling you could probally go with a lighter weight in the rear. I use dino oil also.
05 RUBI
wes19d is offline
post #3 of 6 Old 04-01-2009, 04:54 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #4 of 6 Old 04-01-2009, 05:00 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The FAQ has good info on fluids.
Fluid information here - fill capacities, recommended types of fluid, etc.
2.5L 4 cyl - 4 quarts
2.4L 4 cyl - 5 quarts
4.0L 6 cyl - 6 quarts
Transmission:
30RH 3 speed auto - See post #2 below
32RH 3 speed auto - Approximately 4 quarts ATF+3 when drained via dropping the pan / Approximately 8 quarts dry fill (see post #2 below for fill procedure per the FSM)
42RLE 4 speed auto - Approximately 4 quarts ATF+4 when drained via dropping the pan / Approximately 8.8 quarts dry fill
AX-5 5 speed manual - 3.3 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in the FSM)
AX-15 5 speed manual - 3.32 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in the FSM)
NV3550 5 speed manual - 2.1 quarts Mopar fluid part # 04874464AA or Synchromax (meets Mopar MS-9224 specs)
NV1500 5 speed manual - 2.4 quarts Mopar part # 04874464AA or Synchromax (meets Mopar MS-9224 specs)
NSG370 6 speed manual - 1.58 quarts Mopar part # 04874464AA or Synchromax (meets Mopar MS-9224 specs)
Transfer Case:
231 - 1.1 quarts ATF+3 or ATF +4
241 - 2.1 quarts ATF+4
Axles:
Dana 30 - 1.25 quarts 80W-90
Dana 35 - 1.75 quarts 80W-90 or 75W-140 *
Dana 44 - 2 quarts 80W-90 or 75W-140 *
Rubi Dana 44 (FRONT) - 1.375 quarts 75W-140 synthetic
Rubi Dana 44 (REAR) - 2 quarts 75W-140 synthetic **
*4 oz of friction modifier is required with Trac-Lok limited slip differential.
**Friction modifier is NOT required with Tru-Lok locker/limited slip differential (factory Rubicon locker).
Coolant:
2.5L - 9 quarts
2.4L - 10.1 quarts
4.0L - 10.5 quarts
Wheelin98TJ is offline
post #5 of 6 Old 07-24-2012, 02:17 PM
jeff1234
97 wrangler fluids and how to tell what type rear axel
not to sound stupid but how to i know what trans and rear end and axel type i have in our 97 jeep wrangler 4 cyl 5 speed 4x4?
jeff1234 is offline
post #6 of 6 Old 07-24-2012, 02:25 PM
TheRealKTrain
JK Wrangler
Dana 35.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
amount/type of differential fluid to use in ford 8.8? beertinted TJ Wrangler Technical Forum 8 05-18-2007 06:38 PM
What type of Differential Fluid? his15153 TJ Wrangler Technical Forum 12 02-12-2006 03:11 PM
Identifying differential type voigtrobert TJ Wrangler Technical Forum 20 12-12-2005 04:47 PM
Differential Type Question LSJacobson1@com TJ Wrangler Technical Forum 8 03-20-2005 09:40 AM
Differential fluid / Transfer case fluid varsityboyz TJ Wrangler Technical Forum 4 09-07-2004 05:45 PM
