Two inch body lift= 2 Inch motor mount lift? - JeepForum.com
post #1 of 13 Old 10-11-2008, 12:18 AM Thread Starter
TOLjeep
If i were to do a 2" BL would I need a 2" mml?
Like:http://browndogindustries.com/cu2569...lexrubber.aspx
2003 Jeep Wrangler Sport Dana 30 Front, Dana 35 Rear, 5 Speed
2.5'' Rough Country Suspension
33x12.50 Mud Grapplers on 17" Black Rock Vipers
Mopar Rubicon Rockers,Warn Front Bumper, Bestop Rear Bumper, Banks Exhaust, K&N FIPK
Next: 1.25 Inch Body lift, SAVVY Corner Armor and Steering, PSC Rocker Knockers
Down the Road: Ford 8.8, 3 Inch Springs, 35" Mud Grapplers on Black 20's
TOLjeep is offline
post #2 of 13 Old 10-11-2008, 12:38 AM
krawler510
You don't need a MML to do a BL.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #3 of 13 Old 10-11-2008, 03:06 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i ran a 2" BL with no MML for years i just recently added a 1" MML
RnEmOvr is offline
post #4 of 13 Old 10-11-2008, 03:57 AM
Libtekguy
No MML required. Even if you did a 1" MML, you'd still need to drop the radiator shroud a little bit.
Current: 2014 WK2: 2" Eibach. 20" Overland wheels. 275/55R20 BFG KO2.
Libtekguy is offline
post #5 of 13 Old 09-28-2011, 06:49 PM
geyo
AND? worth it?
NO? Yes? Go bigger(2in MML)?
geyo is offline
post #6 of 13 Old 09-28-2011, 08:33 PM
wolfcreek
2 inch MML is pretty extreme and chances are if you are asking you don't need one.
wolfcreek is offline
post #7 of 13 Old 09-29-2011, 02:03 AM
geyo
No I do. I just dont know to get the 1 inch or 2 inch dont want to do all the work for null...
geyo is offline
post #8 of 13 Old 09-29-2011, 02:22 AM
wolfcreek
Not trying to talk to you out of the MML... I'm about to install one myself. I'm just saying 2" is fairly rare... check out the FAQ on the brown dog website at
http://browndogindustries.com/frequent-questions.aspx
post #9 of 13 Old 09-29-2011, 05:20 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
NEVER use a 2" MML on a Jeep.The 2" BL will come with the brackets to relocate the fan shroud and NO MML is needed for any BL.
TheBoogieman is offline
post #10 of 13 Old 09-29-2011, 05:21 AM
roundlitefan
roundlitefan's Avatar
Well, I have to ask...If you are doing a 2" BL, why wouldn't you do as much MML as you can get away with so that you can tuck everything up and run a flat skid?
roundlitefan is offline
post #11 of 13 Old 09-30-2011, 12:57 AM
geyo
I put electric fan in because the clown I bought it from just cut the shroud and put in a smaller fan. With that said. Do I need the mml? Does it help with function or reduce wear n tear? Thinking more for driveshaft tyranny etcetera.
geyo is offline
post #12 of 13 Old 10-01-2011, 08:15 AM
BahamaStu
You are lifting the body, the motor. trans. tc, axles do not move.
The only advantage you would gain with a mml is clearance under the oil pan and to a certain extent the tranny, and change the drive shaft angles.
BahamaStu is offline
post #13 of 13 Old 10-01-2011, 09:36 AM
freeskier93
But you are moving the radiator and shroud.
With more than 1" of motor lift your going to start having issues with the fan angled in the shroud which will poorly effect cooling abilities.
freeskier93 is offline
2 inch motor mount lift pigpenn TJ Wrangler Technical Forum 21 10-11-2016 01:58 PM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2006 lj with 1'' body lift and belly up skid plate and 5/8 inch motor mount riser's superphreak169 TJ Wrangler Technical Forum 4 04-27-2009 06:23 AM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
