Two Grand to spend - JeepForum.com
post #1 of 14 Old 07-19-2012, 12:12 AM Thread Starter
drumfreek
Two Grand to spend
Everything on my Jeep is stock. What do you recommend I purchase? My first purchase is definitely 32" tires.
Love my Jeep. My secret redheaded love!
02' Sport, 4.0L, 3.73, 5 speed, D44/D30
drumfreek is offline
post #2 of 14 Old 07-19-2012, 12:18 AM
brianmlove
Body and under armor
brianmlove is offline
post #3 of 14 Old 07-19-2012, 01:04 AM
Tamatacan
Rear locker.
Tamatacan is offline
post #4 of 14 Old 07-19-2012, 01:31 AM
jbjeepfever
Tummy Tuck and all the things that go with it.
jbjeepfever is offline
post #5 of 14 Old 07-19-2012, 07:36 AM
DivineKaos
A proper lift kit.
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #6 of 14 Old 07-19-2012, 08:37 AM
2trucks
If you are going to start wheeling it, go with 33" tires. You will want them eventually anyway. Seven to eight inch rims with 4" backspacing, and 2" budget boost to fit the tires.
Some type of LOCKING differential for the rear. This will be the best 4 wheeling modification you will ever make.
Enjoy!
2003 Rubicon, 5 speed, 33" MTR's, Warn XD9000i, OME 2.5", 1.25" BL, 1" MML. Rokman gas tank, xfer skid, ctl arms, coil correction, and rear bumper. Currie steering.
2trucks is offline
post #7 of 14 Old 07-19-2012, 09:20 AM
brianmlove
Id figure what your long term goal is for the jeep and build it that way without substitung parts along to the way that was suffice until you get what you really want. It may take a little while longer to build up but itll be worth it
post #8 of 14 Old 07-19-2012, 09:20 AM
cmecha
get a 3" suspension lift sye and control arms & 33" tires and locker
"always upgraded, never replaced."
cmecha is offline
post #9 of 14 Old 07-19-2012, 09:50 AM
pmcjeep
Dnt think hes gna swing all that with 2k.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #10 of 14 Old 07-19-2012, 09:58 AM
cmecha
i did but i picked up used tires for 200.00 with out a locker
cmecha is offline
post #11 of 14 Old 07-19-2012, 10:29 AM
brmacdon
Vegas!
'99 TJ, 4.56 gears, 4" SA, 1.25" BL, 35" Mud Country's, winch, bumpers and more!
'77 CJ5, 304, T98, 35's, D44's, SOA and in need of some love
brmacdon is offline
post #12 of 14 Old 07-19-2012, 10:41 AM
Ironhead
this
Ironhead is offline
post #13 of 14 Old 07-19-2012, 10:51 AM
Imped
Imped's Avatar
Build from the foundation up, that's the smart way to do it.
Oil pan skid
Steering box skid
ZJ tie rod
1" body lift
1" MML
High clearance belly skid
That's perfect for stock suspension travel on 32" tires and you're gaining protection, strength and clearance where you need it most. With any money leftover, get a Savvy gas tank skid.
OlllllllO
IndyORV
Imped is offline
post #14 of 14 Old 07-19-2012, 02:19 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Start with an OEM FSM...
Knuckelhead is offline
3 grand-ish to spend...what to buy secondhandloser TJ Wrangler Technical Forum 16 08-14-2009 01:20 PM
how to spend 6 grand 2005LJRubicon TJ Wrangler Technical Forum 24 08-20-2008 11:12 AM
If you had 2 Grand to spend... MN_Sasquatch YJ Wrangler Technical Forum 44 04-28-2007 03:41 PM
A grand to spend UndieYeep YJ Wrangler Technical Forum 18 09-10-2006 03:51 PM
$75 to spend on TJ... CoriolisSTORM TJ Wrangler Technical Forum 17 12-30-2004 07:42 AM
