Turn signal light stuck on - JeepForum.com
post #1 of 8 Old 09-27-2009, 02:53 PM Thread Starter
bikerman02
On a 02 jeep SE the right turn signal light stays on all the time. Both signal lights work just fine outside the jeep. The right light blinks really fast when on one the instrument cluster. Also speratticly the blinker on alarm will sound until ya turn on a blinker then off to quiet it. What would do this? Some time ya can get it to stop doing it by disconnecting the battery other times it doesn't help.
bikerman02 is offline
post #2 of 8 Old 09-27-2009, 03:53 PM
J10
You have a short or bad ground some where.
Follows the wires and take a close look at all connectors. Clean anything that looks dirty.
J10 is offline
post #3 of 8 Old 09-27-2009, 03:55 PM
Junky burp
Try cycling the emergency flashers first.
I would then check the grounds for the light sockets.
I would even change the flasher relay, just for laughs.
After that I'm beat.
Junky burp is offline
post #4 of 8 Old 11-19-2009, 03:09 PM
MikalCarbine
Reviving this thread... I have the same exact problem with my left turn signal. The left signal dashboard indication light stays on constantly and when I actually use my left turn signal it blinks super fast. I noticed that my front facing turn signal on my left side doesn't work at all (even with hazards). I took the bulb out and the connection was rusty so I cleaned it up and dielectric greased it. Still no help. Would a dead bulb be causing this problem? I'm going to get a new one or do some electrical troubleshooting next week.
MikalCarbine is offline
post #5 of 8 Old 11-19-2009, 03:32 PM
Stonz
Moisture? Mine acts funky sometimes after diving in wet conditions
06 Rubicon,BL,35s,alot of Currie,Rokmen,Savvy,UCF TT,Tom Woods,winch,brake upgrade,antirock,outboard Ranchos, coil reloc, etc
On-On!
Stonz is offline
post #6 of 8 Old 11-19-2009, 04:24 PM
Robert J. yates
According to my manual, a fast acting flasher can be an indication of a bad bulb. Best to check all bulbs before swapping parts. The flasher relay which is on top of the steering column under the dash is $50 from the dealer. The turn signal multi function switch is right around $100.
Robert J. yates is offline
post #7 of 8 Old 11-19-2009, 06:06 PM
MikalCarbine
Where in your manual did you find this? I tried looking in mine briefly but couldn't
I'll try buying a new bulb before anything steep
post #8 of 8 Old 11-19-2009, 06:27 PM
fishinjeeper
try bulbs, if not just try to clean out all the female connectors that the bulbs go into.
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
Turn Signal Dash Light Stuck On Jesse_87 YJ Wrangler Technical Forum 22 01-22-2017 01:39 PM
Turn Signal Light TJColumbia TJ Wrangler Technical Forum 0 09-07-2009 10:59 PM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
LEFT TURN SIGNAL DISPLAY STUCK GENE TJ Wrangler Technical Forum 2 03-15-2002 09:33 AM
LEFT TURN SIGNAL DISPLAY STUCK GENE TJ Wrangler Technical Forum 3 03-05-2002 02:30 PM
