Turn signal and flasher wont work - JeepForum.com
post #1 of 23 Old 06-19-2011, 11:42 AM Thread Starter
van1
Hello everyone(anyone),
It seems my turn signals will not work along with the flasher. I have read that it can be the relay, so I picked one up and it still wont work. Was wondering if anyone could think of a different reason before I blow the money on the multi functioning switch? Yes, the fuse is good and it is getting power. Everything else works on the (MFS) except what was noted.
van1 is offline
post #2 of 23 Old 06-19-2011, 11:57 AM
twhditto
twhditto's Avatar
I had a corroded bulb that kept mine from working.
2003 Rubicon, stock - but building - slowly... in Van Buren, AR
twhditto is offline
post #3 of 23 Old 06-19-2011, 12:03 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Turn signals won't work when flashers are on.I'm guessing you really didn't mean what you said.
TheBoogieman is offline
post #4 of 23 Old 06-19-2011, 12:05 PM
hustler905
I would try a new flasher relay. They're pretty cheap.
hustler905 is offline
post #5 of 23 Old 06-19-2011, 12:07 PM
bdrayer
2015 JK Wrangler
I just had the issue where my side marker would work and blinker would work when turned on however it would not stay on as a running light. The passenger side was vice versa, the blinker would work to blink and running light but side marker did not work. I replaced the blinker socket on both which was corroded in the same place, the center pin. After replacing that my driver side worked perfectly. The passenger side side marker was corroded but after using a little pb blast and a small brush and cleaning it out very well, everything works and I finally have all my lights working.
Sockets could be the issue, which I got at the dealership for 12 bucks and, or it could be sockets being corroded or bad. Try replacing blinker sockets and then cleaning the side marker sockets.
Hope this helps.
bdrayer is offline
post #6 of 23 Old 06-19-2011, 12:18 PM Thread Starter
van1
Actually I did mean what I said,"It seems my turn signals will not work along with the flasher". Said nothing about turn signals working with flashers.
note: I did replace the flasher. My other lights work, except turn sig. and flashers. I'll check corrosion. But, I think I better get ready to fork out $118 to auto-zone....
van1 is offline
post #7 of 23 Old 06-19-2011, 08:16 PM
Chad184
I had an issues that sounds alot like yours. replaced the bulbs, cleaned the grounds and checked the flasher. It ended up being the socket the light plugs into. Replaced the socket and it works fine. Driver side turn signal.
Chad184 is offline
post #8 of 23 Old 06-19-2011, 08:51 PM
MooSe7
$118 for what?
2004 Wrangler Sport
2006 Grand Cherokee Laredo
MooSe7 is offline
post #9 of 23 Old 06-20-2011, 01:26 PM Thread Starter
van1
The MFS from auto zone=$118
van1 is offline
post #10 of 23 Old 06-20-2011, 01:30 PM
TheBoogieman
You must have factory fog lights on the switch.If you don't,the switch is much cheaper.
post #11 of 23 Old 06-20-2011, 09:09 PM
MooSe7
I have factory fogs too.. Paid $50 or so at O'Reilly
2004 Wrangler Sport
MooSe7 is offline
post #12 of 23 Old 06-24-2011, 12:05 AM
skikodiak
Picked up a 2000 TJ tonight, no brake lights, no turn signals, no 4-way flasher. Fuses okay, sprayed electrical contact cleaner into 4 way flasher part of switch. Now have brake lights and 4-way flashers. Still no turn signals, but out of cleaner. Will try flooding it tomorrow. Lots of years fixing electricla problems, that stuff is magic for switches.
skikodiak is offline
post #13 of 23 Old 06-24-2011, 12:52 AM
Necko2529
Necko2529's Avatar
I'm surprised Boogie didn't suggest flushing your blinkers and adding some aftermarket fluid.... Boogie, love your posts I always find them humorous that's why its kinda hard to believe you have to get rid of your jeep for the reasons you stated in a different thread , if true, I'm really sorry
Necko2529 is offline
post #14 of 23 Old 06-24-2011, 05:13 AM
batman0330
I just had a similar issue and it turned out i had a wire corroded through (was on my passenger brake light). Brakes worked, blinker worked, running light was off. Hope it helps...
batman0330 is offline
post #15 of 23 Old 06-27-2011, 10:51 AM Thread Starter
van1
Thank for the info... I might have just wasted my money...will find out when I can mess with it agin.
van1 is offline
Turn signal flasher vijay YJ Wrangler Technical Forum 3 05-07-2011 01:45 AM
Turn Signal Wont Work Tompatt YJ Wrangler Technical Forum 8 07-06-2010 05:44 PM
Right Turn Signal Wont Work With Lights On? EaglesSJ TJ Wrangler Technical Forum 7 03-03-2010 04:40 PM
2003 jeep wrangler (turn signal flasher; HVAC fan switch does not work on high) lkbuffk TJ Wrangler Technical Forum 3 08-28-2009 07:30 PM
Turn signal flasher 93Sahara TJ Wrangler Technical Forum 1 10-23-2003 02:50 PM
