Turn signal and Emerg flashers. . .Now what - JeepForum.com
post #1 of 13 Old 09-27-2012, 05:12 PM Thread Starter
mparks813
Ok so my 2001, 4.0L Auto TJ was working fine (fine-ish) three days ago. Then my turn signals and emergency flashers stopped working. No clicking, no lights blinking.
Fuse behind the glove box is good, all of the bulbs look good, I just replaced the combo flasher unit (frome the dealership $36.00). Is the four-way switch the next suspect? I initially ruled it out because the brights/dim switch and the dome light piece of the switch works fine.
Is there anything else I can try to isolate the fault to the 4-way switch on the steering wheel column?
Thanks
mparks813 is offline
post #2 of 13 Old 09-27-2012, 06:49 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
1st try working the flasher switch on & off a bunch of times. Often the contacts get dirty from non-use. For the record you have 2 fuses, #13 that you checked is for the signals, #11 in the PDC in front of the battery for the flashers. Since neither work it's not likely the fuses.
Rubi4MyMrs is online now
post #3 of 13 Old 09-27-2012, 06:56 PM Thread Starter
mparks813
Thanks for the info I'll look at #11 and report back
post #4 of 13 Old 09-27-2012, 07:12 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
OK but work the flasher switch too.
post #5 of 13 Old 09-27-2012, 07:51 PM Thread Starter
mparks813
Alright tried the flasher switches repeatedly and looked in the engine compartment in position #11 it was blank and listed a "IOD Storage" ??
post #6 of 13 Old 09-27-2012, 09:28 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
OK try fuse 7 that is for 2002 but there can be some crossover.
post #7 of 13 Old 10-11-2012, 10:45 AM Thread Starter
mparks813
And "7" was the right fuse in the PDC and it looks good. I changed out the MFS on the column and still not working. I noticed that the male connector on both the turn signal /headlights side and the wiper side of the switch both looked cracked and burnt? Any idea where I can locate replacement male plugs? I've checked Morris and autozone.
post #8 of 13 Old 10-11-2012, 01:48 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
post #9 of 13 Old 10-13-2012, 01:10 PM Thread Starter
mparks813
So now the dealer is $70 bucks richer. And for $70.00 I got a plastic bag full of parts that will allow me to put the plug together myself. . . sigh
Any tips or techniques I should know before I start to put the plug together?
post #10 of 13 Old 10-13-2012, 03:39 PM
DBLJ
DBLJ's Avatar
Do one at a time.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #11 of 13 Old 10-13-2012, 04:59 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
^^right, one wire in the wrong place & you have more problems than you started with.
Once the connector or terminals are damaged there is not any other way to repair it.
post #12 of 13 Old 10-13-2012, 05:36 PM Thread Starter
mparks813
OK Thanks for the info. I was assuming I'd cut the the whole bundle and go for it (Using posted wiring diagrams). One wire at a time, got it
post #13 of 13 Old 10-16-2012, 02:55 PM Thread Starter
mparks813
OK so new plug is installed. Turn signals and Haz Flshers still not blinking. I did notice last night that when I have the brakelights on and I turn on the turn signal the corresponding brake light goes out. So. . . a short in the wiring??
turn signal
Turn signal/flashers not working 98TJpos TJ Wrangler Technical Forum 6 07-25-2013 04:48 PM
Turn Signals and Flashers won't work weed TJ Wrangler Technical Forum 2 06-25-2009 08:05 AM
Voltage Drop When I turn on Flashers or Signal Lights KarPC YJ Wrangler Technical Forum 4 07-11-2007 12:34 PM
turn signals, emergency flashers firefitr26 TJ Wrangler Technical Forum 5 06-09-2004 03:41 PM
