turn signal/brake light problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > turn signal/brake light problems
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 06-20-2009, 06:19 PM   #1
m1kemcc
Sometimes my brake lights (all three) come on by themselves. Sometimes my L dash turn signal indicator comes on when I apply the brakes, but will clear if I adjust the turn signal switch position, and it always goes out when I take my foot off the brakes. The L turn indicator always works properly, even when braking.
On rare occasions my L marker lamps will be on with the engine and all lights shut off. I just had to recharge my battery because of this. I thought perhaps a bad ground on my trailer harness was causing this, but I just had that rewired, and it did not resolve the problem.
I've had this problem since I bought the Jeep several months ago. I have to wonder if I have more than one problem going on here?
m1kemcc is offline   Reply With Quote
Unread 06-20-2009, 06:41 PM   #2
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like a common problem. The tail lights (all, brake, turn, reverse, & park) all ground through the screws holding the tail light housings to the body. Sometimes the ground connection isn't so good. Usually just removing the lense cover, then removing & reinstalling the screws one at a time will improve the ground.
Your problem seems to sound like a bad ground is causing the power to "back-feed" through the other circuits "looking" for a place to ground out. Being as the left turn signal indicator light is the one coming on, my money would be riding on the ground being poor at the left rear tail light mounting screws.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-20-2009, 07:06 PM   #3
Jasen
What Max said.
Also, if the brake lights come on by themselves, that might be a switch adjustment issue. I'm guessing your 99 takes the same brake light switch as my 98, which menas there is no adjustment. By hand push the pedal and let it up slowly, check if lights are on, if so pull up on brake pedal and check lights. If out you probably need to tweek the bracket. You have to grabe the switch bracket with a big pair of channel locks or the like and bend it towards the floor a very little bit, then actuate the prdal slowly by hand.
Just went through this with a new switch.
I'm a Journeyman woodworks,
Every projects a journey man.
Jasen is offline   Reply With Quote
Unread 06-20-2009, 07:51 PM   #4
patduke90
Mine does the same thing. You can try taking off the switch and cleaning it inside or you can just learn to live with it like I've done. Mine actually got rained on and worked correctly for a few days, but it eventually went back to the broken status.
patduke90 is offline   Reply With Quote
