Turn Signal and Brake Light - JeepForum.com
post #1 of 9 Old 08-07-2005, 12:17 PM Thread Starter
Jeep_Grrl
Ok I read this but my problem is that my brake lights also do not work. However, my hazards works fine, the reverse lights are fine and the lights in the back also light up when I turn on my headlights. I haven't checked fuses yet, but I'm a little confused about the relay that was mentioned....
Anyone had these probs just from what I mentioned above?
Going to go check the fuse(s) now.....
Jeep_Grrl
99 TJ Sahara
Jeep_Grrl is offline
post #2 of 9 Old 08-07-2005, 12:33 PM Thread Starter
Jeep_Grrl
Nevermind - one of the typical afternoon FL showers is coming down - will have to chekc the fuses later, but if anyone has a piece of advice they are willing to share..........
thanks
Jeep_Grrl
99 TJ Sahara
post #3 of 9 Old 08-07-2005, 04:06 PM
lsufanjeeper
lsufanjeeper's Avatar
thanks
sorry no help on the problem but i do hate florida rain showers!!!!
'98 Black TJ Sahara Soft Top
Member Of The "Playground" Jeep Club #03
Rubicon Express 3.5
BFG AT'S 33x1250x15'S
Got A 25,000 Tow Strap And Some Chains
Fabricated Shovel Mount On Inside TailGate
Midland Cb With 3' Firestick Channel 21
Some Cool Cosmetic Mods
Brush Guard
JKS Quick Disco's
Hood Mounted Highlift On The Way
Teraflex Steering Skid Plate
Hurculined
Hot Chick Riding Shotgun
Winch
GEAUX LSU TIGERS
.__0_0_0_0
[l_,[____],
l---L -OlllllllO-
()_) ()_)---)_)
lsufanjeeper is offline
post #4 of 9 Old 08-07-2005, 06:42 PM
grinwa
grinwa's Avatar
Have you checked the switch on the brake pedal. Disconnect the switch and jumper across it. If the lights come on then it is the switch. If not look farther up the wiring. Good luck
Greg
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #5 of 9 Old 08-11-2005, 10:41 AM
CubFan
Make sure that your rear tail light bulbs are double filament bulbs and both filaments are good. I had similar problems noone could resolve, and when I checked the bulbs, the previous owner had put the wrong bulb (single filament) in the right rear. My RH turn signals would come on, but not blink, turn signals would not work at all if headlights were on, and when I mashed the brake pedal, my dash lights would come on. I fixed all this with one $2 bulb......
CubFan is offline
post #6 of 9 Old 08-11-2005, 12:49 PM
linux24
Change your brake light fluid.
linux24
Jeep newbies and novice mechanics go here:
linux24 is offline
post #7 of 9 Old 08-11-2005, 02:23 PM
Randall Flagg
Way to offer constructive advice linus24. Anyway, I had pretty much the same problem but it was in a chevy truck. In the chevy it turned out to be the turn signal combination switch (Turn signal stalk and assy) RF
Randall Flagg is offline
post #8 of 9 Old 08-11-2005, 02:49 PM
Dusty1718
Dusty1718's Avatar
RF usually more than just the brake lights wont work when its the combo switch and it will do wierd things in wierd combonations with the light. the switch designates what to do, and when to do it so when it goes lots of funny things happen, check the fuses first and foremost, keep us updated. also jump the brake light switch as stated if the fuse is good.
-Dustin
Chrysler/Jeep/Dodge Master Technician
Dusty1718 is offline
post #9 of 9 Old 08-13-2005, 03:24 PM Thread Starter
Jeep_Grrl
I think it was my muffler bearings - but after changing out my fuses and drying a few things out at least the brake lights works. who needs a turn signal anyway?
Jeep_Grrl
99 TJ Sahara
turn signal/brake light problems m1kemcc TJ Wrangler Technical Forum 3 06-20-2009 07:51 PM
right turn signal and brake light not working DMC0627 TJ Wrangler Technical Forum 4 05-20-2009 04:23 PM
Separating turn signal from brake light? TJmudpuppy TJ Wrangler Technical Forum 11 12-11-2008 01:41 PM
Turn signal/brake light problem Help! ksm279 TJ Wrangler Technical Forum 3 04-07-2008 11:24 AM
RT Turn Signal/Brake light tjtone TJ Wrangler Technical Forum 2 03-30-2007 12:27 PM
