Turn signal alarm and blown fuse - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Turn signal alarm and blown fuse
July 4th Sale Event! and Yes, We're Open!Metalcloak: Celebrate Freedom with Free ShippingThe Cure for your Tie Rod Roll!
Unread 06-07-2015, 08:37 PM   #1
SWAustinJeep
I am having a new problem with 98 TJ ( manual, 4 cyl , 140,000mi).
When I engage the (R) turn signal there is a short "buzzing" alarm ( not a chime) then the fuse burns out. This occurs immediately and every time engaged. The (L) signal works properly. When using hazard flashers, the alarm sounds constantly and the flashers do not work but the fuse does not blow.
All the bulb sockets look good ( no corrosion) and the bulbs look good and work except when using the (R) turn signal. I replaced the turn signal switch on the steering column and the problem persists.
Any suggestions on how to proceed.
TIA
SWAustinJeep is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 01:57 AM   #2
Jonny Jeep
Jonny Jeep's Avatar
The buzzing is not an alarm. It's the flasher relay opening and closing contacts die to a low voltage across the coil. As the problem is on one side there is a problem on that side. As you've already checked the bulbs and sockets the problem may be a ground problem.
Rear are grounded by the mounting bolts to the tub. Front are grounded on the rear of the grill near each headlight.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 02:33 AM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Bolts Jonny, bolts...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 03:20 AM   #4
Jonny Jeep
Jonny Jeep's Avatar
I think the spell check on my new mobile is dyslexic. Corrected, thanks.
