#1 | |
Turbocharged 2.4L for my TJ!!!
Well I bought a Turbo 2.4L out of a PT crusier to day, I will be replacing my 2.4L out of my jeep it only has 17,000 miles on it.
the new engine only has 400 miles on it so it should be a fun conversion. I have some clearence issues but nothing big I will be writing and showing pic's as I go Here's some info for you: Engine Configuration I Cylinders 4 Aspiration/Induction Turbocharged Displacement 2.00 L | 122 cu in. | 1999.6 cc. Valvetrain DOHC Horsepower 215.00 BHP (158.2 KW) @ 5100.00 RPM Torque 220.00 Ft-Lbs (298.3 NM) @ 2800.00 RPM
YES My old jeep is RUNNING A 2.4L TURBO MOTOR If you want to know http://www.reno4x4.com/forum/turbocharged-2-4-me-t5362.html?t=5362 Last edited by Air Sierra; 09-01-2009 at 11:44 AM.. |
#3 | |
#4 |
Badass98TJ
#5 |
I want to rape a twin turbo motor out of a supra and throw it in the heep... that would be sick...
#6 |
light weight and good on gas and good torque........
YES My old jeep is RUNNING A 2.4L TURBO MOTOR If you want to know http://www.reno4x4.com/forum/turbocharged-2-4-me-t5362.html?t=5362 |
#7 |
Conversion
Converting an engine designed for FRONT wheel drive to REAR wheel drive will be interesting for sure. It looks like all the turbo stuff will be right up against the firewall with little if any room for the hoses.
The radiator hoses will be much longer. You might want to consider if the transmission can handle the torque. Will a new computer be required? Good luck and take lots of pictures. Thanks.
2003 SE Dark Khaki & Dark Khaki Hardtop POS NVG1500 Transmission Stock except for the TrueTrac out back Garvin Wilderness Front and Rear Bumpers It's only a machine. You can love it if you want but it will not love you back. VOTE! |
#8 | |
i know a few for sale around here if ya want one....not cheap though... nevermind IM gonna be the one to do that! |
#9 |
ya how would u convert a front wheel drive engine into a rear wheel drive vehicle i'm trying to think how u would do it
RIP: 97' TJ on 35's (rolled) 03' Mustang GT Turbo Vert |
#10 |
Wow, I am excited to see the results of this conversion...
*2003 Rubicon TJ (work in progress) *2006 Grand Cherokee Overland Edition (Hemi-nator) |
#11 | |
Fish fear me
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#12 | |
i would imagine that the existing motor mounts will work just fine with the engine. i wouldn't imagine that installing the motor would be all that bad, really. need an adaptor for the tranny, some custom stuff here and there. but a lot of the electronics should be compatable with the existing stuff. it has got to be no harder than converting a 2.4L to a 4.0L im looking forward to seeing how this turns out. not that it helps me because i have the 2.5L, but its cool to see this tried.
2000 Jeep TJ SE Amberfire Pearl- Sold, I miss her 1995 Escort LX 2005 PBM M6 GTO |
#13 | |
Well seeing what that engine was pulled from ,the tranny may just bolt right up.The 2.4 standard engine for the jeep IS the same engine that is used in the PT. : http://en.wikipedia.org/wiki/Chrysler_Neon_engine#2.4
06 Solar Yellow SE 4Banger,MT classicII wheels ,some Tuffy stuff,Hella lights,50Lb bumpers & more to come................................. :) |
#14 |
Why not take the turbo assembly and stuff from the PT engine and put them on your jeep then?
#15 | |
that thinking that too aren't the manifolds the same>?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
