turbo 4.0 questions - Page 3 - JeepForum.com
post #31 of 32 Old 07-15-2010, 08:59 PM
rubidriver
Originally Posted by sundowner View Post
i'm surprised there hasn't been more discussion on how a 4.7 stroker might work...
With that said, i used to be of the opinion that a turbo was a very, very bad idea in a jeep. However, i have to admit: It can work, and quite well at that. As has been said, it all has to do with airflow and proper sizing. Turbos can make some serious power...however, there's just one more small fact that the op needs to consider: the rest of the drive train.
if you're going to put 250+ to the rear wheels, then you're going to have - in my opinion - to do some serious beefing up, or parts will start failing...especially if you're driving it hard on the street.
exactlyyyyy
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #32 of 32 Old 07-16-2010, 04:59 AM
GIJohnnyB
Originally Posted by rubidriver View Post
Na man its speculation.
First, yes the turbo can only spool so much.. what is your alternative? A supercharger? Ok, lets stick a small pulley on the SC to make tons of boost and blow it up before it gets out of the shop.
Second, your acting like there are just big and just small turbos out there. If sized right you can find your medium and it will make more than enough power.
Third, if your not happy with my "second" then you need go ahead and get together with the guys from Porsche and get you a variable speed turbo, so you can have the best of both worlds and be happy. Just a little warning tho, you arent going to come back bragging how cheap it was to us later with this choice.
A supercharger with the right pulley will give you a more linear power curve through a wider range of RPM. This will at very least allow you to somewhat control your torque instead of dumping it all at once at a certain RPM like turbos do. All said and done, no matter what kind of forced injection you run, its going to come back to drivetrain...are you going to just spin through gears making them useless? Will they stand up to the extra power?
Trust me. Going through transmissions every other time you bring your vehicle out is no fun.
GIJohnnyB is offline
4.0 i6 , i6 , turbo
turbo YJ? skeeterbeater YJ Wrangler Technical Forum 62 01-10-2010 09:31 PM
turbo? jmoney405 TJ Wrangler Technical Forum 49 05-23-2008 06:56 PM
2.5 Turbo Questions? isubwrx YJ Wrangler Technical Forum 13 08-27-2006 02:47 PM
Turbo Kit Questions Parts Pimp TJ Wrangler Technical Forum 33 08-31-2005 08:48 AM
Turbo On A Tj/ Fuel Questions nitrous nazi TJ Wrangler Technical Forum 14 12-12-2002 03:20 AM
