turbo 2.4l (a different way) - JeepForum.com
post #1 of 36 Old 06-23-2011, 08:40 PM Thread Starter
krazzyboy_1
so i put a turbo on my jeep. .48 A/R 60 trim T3 stage one housing on a ATP log manifold and 38mm precision wast gate. and i am already thinking of the next step, SRT4 head pistons rods. and am wondering if anybody has any experience with AEM FIC or other tuner. before you ask i will have pics next week it is in the shop getting the exhaust finished up. i am hoping on over 300hp one day.
DOHC 2.4L Turbo.
krazzyboy_1 is offline
post #2 of 36 Old 06-23-2011, 10:12 PM
rs4race
Does the srt4 parts fit the jeep motor? more info please.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #3 of 36 Old 06-23-2011, 10:37 PM
ohtenwillys
thats why its called a 2.4 neon
ohtenwillys is offline
post #4 of 36 Old 06-23-2011, 10:47 PM
liftedon37s
A turbo jeep, I like. Hopefully you don't do alot of rock crawling bc turbo spool would be killer then.
It has some things done to it.
liftedon37s is offline
post #5 of 36 Old 06-23-2011, 10:50 PM
rs4race
Interesting.... I know the srt4 can make alot of power easy.
As far as the AEM.. I have experience tuning the AEM ecu for a nissan 240sx. Its a really nice unit, the tuning program is pretty easy to use.
My Build
rs4race is offline
post #6 of 36 Old 06-23-2011, 10:54 PM
rs4race
Turbo lag seems to be a common misconception. I built a turbo motor before, and the bottom end made more power than n/a. The turbo lag was just where the turbo really started spooling. The whole tq curve was above what the same motor makes n/a.
My Build
rs4race is offline
post #7 of 36 Old 06-23-2011, 10:58 PM
LiveAndLearn
I miss my Audi S4.... Lets see pics of this.
LiveAndLearn is offline
post #8 of 36 Old 06-23-2011, 11:07 PM Thread Starter
krazzyboy_1
with the set up i have the boost will turn on under 2000 rpm. the turbo i have is almost to small for the engine but am not going to run the rpms up much so it wont choke out the engine. yes most if not all the parts off the srt will swap on the 2.4 the best things are all the after market support, but the ecu is the hurdle at this point i dont need it right now but it is next on the list.
DOHC 2.4L Turbo.
post #9 of 36 Old 06-23-2011, 11:13 PM
Juniosjeep
I have been considering this upgrade myself on my 06 TJ 4 popper. Can someone with basic car knowledge install?also I hate to be nosy, what did the upgrade run you....
Juniosjeep is offline
post #10 of 36 Old 06-23-2011, 11:25 PM Thread Starter
krazzyboy_1
i did most the work my self. i am paying to have the exhaust put on and done right, will have it back next week. i will have 2500 in it so far but it is just the beginning i could stop now if i wanted to but i need more power. i used high end parts as well you could save some coin on a few things.
DOHC 2.4L Turbo.
post #11 of 36 Old 06-23-2011, 11:55 PM Thread Starter
krazzyboy_1
ATP manifold- $400
custom t3 turbo -$500 (usedturbos.net)
precisions wast-gate - $275
AEM wide-band o2 - $200
custom flange spacer - $150 (can have others made)
oil lines - $60
misc. parts - $300 (intake hoses, random hardware)
exhaust - $TBD
DOHC 2.4L Turbo.
post #12 of 36 Old 06-24-2011, 10:42 AM
alexherb
I would assume the SRT internals are setup to run a lower CR in order to handle more boost. but (only assumption) they are tuned to make their power in a much higher RPM range that what you typically run at.
Are you still running the stock injectors? it may limit you in your tuning if they cant handle the increased fuel load.
I used TurboEdit on my turboed hondas, i dont know if there is similar support for other applications. but it was MUCH cheaper and had a TON of adjustments. It solved the problem of overcoming the stock mapping. Stock ecus only have maps from full vaccum to zero vaccum, if it sees positive pressure it runs in a "default" mode which is crazy rich (safe).
turboedit - http://www.xenocron.com/te.php?page=starting
alexherb is offline
post #13 of 36 Old 06-24-2011, 03:51 PM
RubyMax3388
intercooler or water injection or nothing?
RubyMax3388 is offline
post #14 of 36 Old 06-24-2011, 04:01 PM Thread Starter
krazzyboy_1
still on stock injectors but have srt stage 1s on the shelf. not running any cooling right now but that will change. i have it set at 5psi for now till i get the tuner in and a few other things. my engine has a comp of 9.4:1 srt4 is 8.5:1 but the srt has forged pistons and rods.
DOHC 2.4L Turbo.
post #15 of 36 Old 06-24-2011, 04:12 PM
Juniosjeep
My TJ is pretty much stock under the hood w/ the exception of a cold air intake and mine is definetly no powerhouse, but runs well for what it is. So I'm curious how much of a diff did the current upgrade gave you? I know I could definetly use some more hill pulling power as I travel from Charlotte NC to Morgantown WV a few times a year. I'm not looking for too much but just a little more than it than it currently has. I get fairly good gas milage w/ my jeep now even with some slightly larger tires. I do most of my driving in the Charlotte area and it's pretty flat here, not many hills to climb. Also did the upgrade change the sound much?? Mine has a very deep sound from the stock exhaust and I also get a slight air swishing sound as I shift then get in the gas.....did your 2.4 do the same?
2.5L turbo TJ kolten493 TJ Wrangler Technical Forum 61 02-14-2012 06:24 AM
??? 2.5 with turbo or v6 97okwrangler TJ Wrangler Technical Forum 4 12-14-2008 12:07 AM
350 turbo mean90yj YJ Wrangler Technical Forum 3 08-31-2007 12:15 PM
2.5 turbo hare717 TJ Wrangler Technical Forum 3 04-02-2007 07:08 PM
3.8 turbo in the YJ sailor77 YJ Wrangler Technical Forum 7 07-20-2004 10:35 PM
