tummy tuck, without tuck - Page 2 - JeepForum.com
post #16 of 27 Old 12-10-2007, 09:02 AM
HipCheck_1
Originally Posted by mdm
This cross member is part of 33Engineering's skid. The low profile transmission mount is a separate piece that replaces the stock mount and can be used with the 33Engineering skid or other skid (to include the stock skid) by drilling holes. The mount lowers the transfer case and allows you to install a belly up type skid with less interference between the transmission/transfer case and the tub. Used with the stock skid it can act as a transfer case drop to reduce drive shaft angles.
Ahh man, I was totally confused. You are right. To the OP on this web site:
http://www.offroadtoystore.com/Merch...t_Code=33-1650
it says this:
Use as a transfer case drop. Since the mount is 1.5" slimmer than the stock mount, your tranny will be 1.5" lower. This can be used with the stock skid plate to negate some of the increase in driveline angles from a suspension lift kit.
It also says it works with the 03-06 TJ w/manual transmission. Do they also make one for the automatic? Nevermind, found my own answer:
http://www.offroadtoystore.com/Merch...ory_Code=33Eng
HipCheck_1 is offline
post #17 of 27 Old 12-10-2007, 09:13 AM
Scotch740
Scotch740's Avatar
Your about 80% of the way to being able to do a Flat skid. I used the 33 eng mount 1.25" BL and the Novak shifter, then made my own skid out of 1/4" plate. Check the link in my sig and you can even get a dimensioned drawing that you could take to a local metal place and get them to quote you on it. If you don't have a welder or cutting ability yourself.
Other wise I would just install the SYE and get rid of those vibes. Then save for the 33 eng skid, which is what I would buy if I didn't make my own.
Scotch740 is offline
post #18 of 27 Old 12-10-2007, 11:25 AM
STW
it says this:
Use as a transfer case drop. Since the mount is 1.5? slimmer than the stock mount, your tranny will be 1.5? lower. This can be used with the stock skid plate to negate some of the increase in driveline angles from a suspension lift kit.
It also says it works with the 03-06 TJ w/manual transmission. Do they also make one for the automatic? (you have 42rle auto tranny right?)
Do I understand this correctly: I could use the t-case drop referred to above to lower the tranny 1.5" and use this to avoid the typical kind of t-case skid drop? Sorry for the hijack question, but I have a 3" susp lift, no BL, and about .5" of t-case skid washer drop. I've been planning a tummy tuck but this makes it sound like I could do the t-case drop referred to above and get rid of the washers. Sounds like I could do this without an SYE (?). Would it require a BL to lower the t-case this way?
Thanks.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #19 of 27 Old 12-10-2007, 12:13 PM
mdm
Farm Wheeler
Originally Posted by STW
Do I understand this correctly: I could use the t-case drop referred to above to lower the tranny 1.5" ...
No you can't. This transmission mount is available for '03-'06 models w/automatic transmission.
mdm is offline
post #20 of 27 Old 12-10-2007, 12:33 PM
HipCheck_1
Your best bet is to call 33 Engineering and see if they have a solution for you.
www.33engineering.com
Contact 33 Engineering at 303-683-8310
post #21 of 27 Old 12-10-2007, 12:59 PM Thread Starter
chadsmeltzer
chadsmeltzer's Avatar
I am now seriously considering your plans, but I need to find a shop around here to do it. Thanks for the write-up
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #22 of 27 Old 12-10-2007, 01:14 PM
Scotch740
Scotch740's Avatar
One thing to keep in mind is I have 0" of lift. You might need to cut out some of my skid design for your front drive shaft. If you have a grinder you can always do that yourself afterwards but they will be able to do it much faster.
The one thing the 33 eng skid has that my design lacked was a separate cross member for dropping the skid. I have to support my trans with a jack if I want to drop my TC skid where the 33eng skid you just unbolt the plate. A very useful and well though out design.
One thing I can tell you for sure is you will be SOOO happy to get rid of the shove, either way you go.
post #23 of 27 Old 01-04-2008, 04:55 PM Thread Starter
chadsmeltzer
Well, I finally got the skidplate...
before
after
about a 4" gain in ground clearance, but now the tranny pan is exposed
post #24 of 27 Old 01-04-2008, 04:59 PM
HipCheck_1
Aww man, you suck.... Just kidding. Looks great.
I got the tranny mount for Christmas, now I need to buy the skid.
Sounds like you need to get a Skid Row Engine Skid or something. It never ends...
post #25 of 27 Old 01-27-2008, 11:09 PM
Edward777
will the skid row engine skid bolt up to the 33 engineering skid...i was wondering if the engine/oil pan skid would sacrifice clearance issues if it didnt bolt up to the 33 engineering
8.8 swap, Aussie FL, 2.25 BB Monotube, JKS quick Disconnects, 15x8 MT classics 32x11.50 SSR
Edward777 is offline
post #26 of 27 Old 01-27-2008, 11:31 PM
AlTheKillerr
AlTheKillerr's Avatar
wow what a huge difference. i cant wait to be able to do a belly up on my jeep
Photographer
AlTheKillerr is offline
post #27 of 27 Old 01-28-2008, 05:31 AM
80 CHOPPER
Yes ,it bolts right up. No,you wont sacrifice clearance.
DRAGON
80 CHOPPER is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck powelltj TJ Wrangler Technical Forum 8 12-30-2008 02:03 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
