Tummy Tuck Skid Exhaust Question - JeepForum.com
post #1 of 8 Old 07-16-2008, 07:30 PM Thread Starter
J-Mox
I was wanting to know how people are modifying their exhaust to clear the skid plate after doing a tummy tuck. I was using "Scotch740"s design for my skid plate but since he has an Unlimited it appears that the muffler is behind the plate. I am also using a low clearance tranny mount from "33 Engineering" in the setup. My muffler is of course is hitting the plate before I can get the skid even close to the frame. So I guess my question is are people raising or adapting the hanger mounts or having a muffler shop cut and re-bend the pipes?
J-Mox is offline
post #2 of 8 Old 07-16-2008, 09:38 PM
UnlimitedNJ
The problem I encountered was that the stock catalytic converter was too close to the floor, so I cut it out and welded in a small magnaflow cat. The design of my skid is very similar to Scotch740's (1/4 plate, angle iron reinforcements and the 33 Engineering mount). I cut a notch in the back of my skid for muffler clearance, as well as tweak the rear exhaust hangers to work with the slightly higher position. Loosening the flange before the muffler helps too, get it into position and tighten it up again, mine is pretty angled and doesn't leak. The bottom of the muffler is even with the skid.
Why don't you go back to your home on whore island?!
UnlimitedNJ is offline
post #3 of 8 Old 07-16-2008, 09:52 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
my exhaust has zero clearance issues, and its all stock. the snaked downtube will rub slightly on either the frame upper control arm mount, or the JeepMedic engine skid if I don't get it perfectly placed, but seeing as i've dropped it 3 times now, i'm getting really good at placing it correctly.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 8 Old 07-16-2008, 11:43 PM
Crashnburn80
Crashnburn80's Avatar
It depends on the skid design. The Nth skid, (which offers some of the most clearance gains) requires zero exhaust mods. It fits with the stock exhaust, the skid just does not extend all the way back to the muffler. Could you just trim your skid to be shorter?
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #5 of 8 Old 07-17-2008, 07:53 AM
Scotch740
Scotch740's Avatar
Glad my write up is inspiring people. Can you post up some pictures of your set up and where the muffler is over lapping the skid? Or at least let us know how much it is? With out seeing that, I would think the suggestions of shortening the skid or notching it, combined with loosening the flange would be your best bet. When you do figure it out please post up in my thread about how you solved those issues.
Other issues I wondering about is the front driver shaft. I am planing on a lift as soon as $ allows and am thinking I will have to notch out a pretty hefty chunk for the front DS. Also considering lowering the skid 1" to help with this as well as with floor board heat (possibly adding shielding) , plus enable me to use my Fumoto oil drain valve.
Scotch740 is offline
post #6 of 8 Old 07-17-2008, 06:02 PM
UnlimitedNJ
About 3" suspension lift on mine and I didn't have to notch the skid for driveshaft clearance.
post #7 of 8 Old 07-17-2008, 06:13 PM
becker21603
becker21603's Avatar
i have the 5.5" RE LA kit that incorporates a tummy tuck design, i had no problems installig it however i am replacing my cat and that is becoming an issue.
5.5" RE LA, 35x12.50 MT MTZ, Eagle Alloy rims, Hella Lights, RE adjustable track bars, Rhino lined, SYE kit custom driveshaft, Warn front and rear bumpers w/ tire carrier, Warn tabor 9k winch, ARB rock sliders, Tru-trac, 4.11's, ARB Snorkel.
becker21603 is offline
post #8 of 8 Old 07-17-2008, 08:02 PM Thread Starter
J-Mox
Thanks for the info guys! I don't have the skid mounted yet but I was mocking it up the other day and the muffler was the main issue with clearance. Since I have a regular Wrangler it appears that the muffler is more forward than the Unlimiteds. The converter seems like there will be plenty of room. I will notch the plate if needed but it looks like it would make a snag point if it was lower than the skid plate. As far as the drive shaft I did not look at that yet but I will keep it in mind to check.
J-Mox is offline
What's the best Tummy Tuck Skid? What CV Shaft to get? Etc? jtice TJ Wrangler Technical Forum 51 05-18-2009 02:05 PM
any one got 33 tummy tuck with a oil pan skid? emahan01 TJ Wrangler Technical Forum 15 04-09-2009 03:43 PM
TNT Tummy Tuck/Flat Belly Skid snellav TJ Wrangler Technical Forum 6 03-20-2008 10:55 PM
skid/tummy tuck Heep TJ Wrangler Technical Forum 12 08-22-2007 07:36 PM
confused about the skid row and nth degree tummy tuck minileprechaun TJ Wrangler Technical Forum 7 05-26-2007 10:19 AM
