Tub Removal Guide? - JeepForum.com
post #1 of 3 Old 05-28-2013, 05:46 AM Thread Starter
mjbinks
Tub Removal Guide?
Hey, rusted body mounts, (two right through). Looking to have some plates welded as a fix but it sounds like it may be better to replace the tub. Anyone got some advice on this?
Also, I'm wondering if anyone can steer me to a decent guide on how to remove the tub? Where are the worst spots on the frame for rust? Basically, I'm thinking I better check the frame before I bother lifting the tub.
Thanks to all!
M
mjbinks is offline
post #2 of 3 Old 05-28-2013, 07:36 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
so its rusted through on the tub or on the frame? just go all over with the frame with a screwdriver and hammer and tap the screwdriver to check for rot. as far as replacing the tub, spray all the body mount bolts with pb blaster everyday for a few days, then remove them, remove the top, remove the fenders, disconnect everything attached to the tub as far as the front wiring harness etc. and lift it off.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #3 of 3 Old 05-28-2013, 07:44 AM
RubiconRazorbac
RubiconRazorbac's Avatar
Frame-side rear lower control arm mounts. A little rust will turn 'em into swiss cheese.
That's where the frame starts to bend upward & there's no drain hole.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
body mounts , change , rust , tub
