Tub liner - JeepForum.com
post #1 of 10 Old 07-31-2012, 09:41 AM Thread Starter
cj_tj
Tub liner
I've been wanting to pull out the stock carpet in my 97 Wrangler and replace it with a lining of some sort...either Rhino or Herculiner...
Any thoughts?
cj_tj is offline
post #2 of 10 Old 07-31-2012, 09:47 AM
4x4summit
Rhino you'd have to pay for them to spray it on and could be costly. All depends on if you want to do it or yourself or have a professional do it. I have heard good things about Herculiner and it comes with everything you should need. Sure there are others on here that have more input. Good Luck! BTW: WE LIKE PICTURES!!!
4x4summit is offline
post #3 of 10 Old 07-31-2012, 09:57 AM
Hesher420
I did my tub in herculiner, along with some of my armor. It gets the job done and is easily touched up if need be. Check out my build thread in my sig for pics of prep and painting.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #4 of 10 Old 07-31-2012, 09:58 AM
bob6987
I did Herculiner and and very happy with it.
Its took 3 days. Gutting the inside, prepping and cleaning and got first coat on. let sit until next morning added second coat. let sit again and then re assembled the third day.
If i was thinking ahead i would have painted the out side edges (getting rattle can paint job) before lining. I like the look of the edges that the roller left. sanding the edges to paint now. I think i will need to touch of the edges with a small can of liner.
I found the using wire wheels to scuff of the paint makes the process a lot faster.
Stuff ear plugs in the holes you don't want filled/coated..i did not do this and have a few drip spots on the ground below.
I would also get a can of the spray on liner to get the places the brush/roller cant get to.
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #5 of 10 Old 07-31-2012, 10:11 AM
SideshowBob024
Monstaliner for the win!!!
Here is mine-
SideshowBob024 is offline
post #6 of 10 Old 07-31-2012, 10:42 AM
Neudiin
Monsta comes in colors and really easy to do. Here is a thread with nuttin but pics of Monstarized stuff =)
Neudiin is offline
post #7 of 10 Old 07-31-2012, 11:09 AM
homebrwd
Thoughts: try searching, there is a wealth of knowledge here. I did that and decided on monstaliner which I will be applying this weekend.
homebrwd is offline
post #8 of 10 Old 07-31-2012, 11:11 AM
rubiconblue
Monstaliner is the way to go , did my rubi about 2months ago and it is holding up perfectly!
3.25 RC / 305/70R16 / Quadratec 9K winch / Monstalined tub.......more to come
rubiconblue is offline
post #9 of 10 Old 07-31-2012, 11:15 AM
Griff1918
After all the reading I have been doing monsta. Is the way I'm going.
Griff1918 is offline
post #10 of 10 Old 07-31-2012, 11:15 AM
Mickey_Mouse
2013 KK Liberty
prep and patience works best for these types of liners. I have hurculiner and 3 coats really gets the job done.
Mickey_Mouse is offline
