Tub Damage - JeepForum.com
post #1 of 12 Old 08-08-2007, 01:16 PM Thread Starter
BYuen
BYuen's Avatar
Tub Damage
Just finished going through Moab Rim trail... and came out with this http://uva.facebook.com/photo.php?pi...&id=1026810062. Not too bad but had to use the HiLift to get myself un-pinned... I was very pleased. So what would one do next with the tub damage!? Thanks.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #2 of 12 Old 08-08-2007, 01:32 PM
Crashnburn80
Crashnburn80's Avatar
Remove or replace the floatie, the spraypaint over the damage with antirust paint (to prevent rust obviosuly) and get a set of bolt on corner guards to cover it up. Since the corner guards are permanet theres no need to worry about repair or getting the paint color perfect. Thats what I did.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 12 Old 08-08-2007, 01:43 PM
JJs99TJ
x2 on adding some "trail corners" to it. i like my Rokmen's
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #4 of 12 Old 08-08-2007, 05:15 PM Thread Starter
BYuen
BYuen's Avatar
Thanks anyone have any good links to the guards besides quadratec? I'll do a search for the Rokmens. Do you think the guards would fit over the bent corner panel?
2001 White TJ Sport
BYuen is online now
post #5 of 12 Old 08-08-2007, 05:18 PM
90SaharaJeep
In all honesty I think it looks pretty cool! just leave it
90SaharaJeep is offline
post #6 of 12 Old 08-08-2007, 05:20 PM
bryans98tj
Here you go:
http://www.northridge4x4.com/proddet...rod=PS-TCORNER
This is a good example for all those that don't want to drill holes in their Jeep. Simple little holes and $150 will save your Jeep and keep it looking good.
Oh and Dave @ Northridge is a good dude.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #7 of 12 Old 08-08-2007, 05:22 PM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
Yup. Pull the floaties off the jeep all around. They are useless and if you plan on taking it off road again this will continue to happen. x2 on the armor. They will look good and cover up everything you have going. If you look at your pic where teh 2 pcs on the tub come together. That is where the new corners will stop so you won't see anything after you are done. I think Black armor on the white jeep would look good. Just my 2 cents
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off)
TrailWorthyFab is offline
post #8 of 12 Old 08-08-2007, 05:29 PM Thread Starter
BYuen
BYuen's Avatar
Yup I did pull the floaties cept the rear ones... haha. That corner is pretty bent if you look at it from a rear angle I sure hope the corner guard would fit.
2001 White TJ Sport
BYuen is online now
post #9 of 12 Old 08-08-2007, 05:33 PM
BILL G
BILL G's Avatar
Or get a set of these from Gen-Right
BILL G is offline
post #10 of 12 Old 08-08-2007, 05:35 PM
RockRunner85
My friend hit the side of his Jeep in that same area with the plow truck. We heated it with a torch and banged it out with a sledge. Some bondo, primer, and spray touch up paint and it doesn't look that bad anymore.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #11 of 12 Old 08-08-2007, 05:38 PM
98tjsahara
slap a band-aid sticker on it and call it good.
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline
post #12 of 12 Old 08-08-2007, 05:42 PM
mrbates
RESIDENT METAL
it may be bent a little to much for the corners to fit perfect, if so get a BFH and pound it back until you get a good fit then repaint as you will likely remove paint with the BFH
I have a Jeep.
2003 X. 3" SA. Locked D44s F/R. 35" MTR-K's
mrbates is offline
Oil pan damage ejparkerusa TJ Wrangler Technical Forum 8 03-15-2009 04:12 PM
how much damage? mean90yj YJ Wrangler Technical Forum 6 10-05-2007 11:15 AM
Damage? rraiderr TJ Wrangler Technical Forum 20 07-15-2007 09:41 AM
Damage? CJO TJ Wrangler Technical Forum 4 05-22-2006 05:58 AM
Too much oil - damage? 4cyl TJ Wrangler Technical Forum 8 01-24-2006 10:12 PM
