Quantcast TSB for 2.4L serp belt??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > TSB for 2.4L serp belt???
Old 03-07-2006, 10:09 PM   #1
Luck881
I've had a squeak develop over the last couple of days, I only hear it while moving and with load on the drive line such as while cruising or accelerating, not while coasting... I took the Jeep to the dealer today expecting something in the front drive shaft a-la "angry sparrows", but they said there is a TSB about replacing the belt and re-routing it. Has anyone gone through this and did the dealer fix work? I'm having the work done later in the week, but I strongly expect I'll be going back soon for the same squeak. Any thoughts are appeciated.
Ian
'05 TJ SE, 2.4L, 6 Spd, 2" Procomp Lift, 31" M/T MTZ's
'09 Ram QC SLT,2.5 levelling kit to come
Luck881 is offline   Reply With Quote
Old 03-07-2006, 10:18 PM   #2
smartshot
It's pro. the belt, i'm pretty sure that will fix it. Maybe some water or something got into it... or the pully's are alittle off.
smartshot is offline   Reply With Quote
Old 03-07-2006, 10:28 PM   #3
SpitNine
Belt?
I have a 2003 SE WITHOUT air conditioning. Currently have 26,000 miles on it. Have had NO problems with the belt.
I would think that there aren't a lot of options for re-routing the belt though unless it was somehow installed wrong at the factory.
Thanks.
2003 SE Dark Khaki & Dark Khaki Hardtop
POS NVG1500 Transmission
Stock except for the TrueTrac out back
Garvin Wilderness Front and Rear Bumpers
It's only a machine. You can love it if you want but it will not love you back. VOTE!
SpitNine is offline   Reply With Quote
Old 03-07-2006, 10:37 PM   #4
Luck881
Supposedly they remove the idler in the center of the block and replace the existing belt with a shorter one. The guy said they'd already done it to another one but I thought for sure I would have read about it happening on here... it doesn't seem all that common a problem. It's kind of a surprise because I only have about 6000Km on it.
Ian
Old 03-07-2006, 10:41 PM   #5
SpitNine
Air Conditioning
Do you have air conditioning?
Thanks.
Old 03-07-2006, 10:43 PM   #6
Luck881
No I don't
this might explain it more;
http://www.alldata.com/tsb/Chrysler/1139990400000_1140768000000_07-001-06/71.html
but, unlike in their description, I noticed it while driving, and in low ambient temperatures.
Ian
Old 03-07-2006, 11:17 PM   #7
wmasstj
03' SE 2.4 w/no air and no squeaks. Thanks for the heads up, if it does start i'll know why
wmasstj is offline   Reply With Quote
Old 03-08-2006, 08:33 AM   #8
SpitNine
Good Info
No I don't
This is good info for those of us with 2.4L SEs.
We now have two replacement belt options.
You'll notice, however, that the original belt routings insured that the drive belt made at least 180 degree contact on all pulleys. I guess this was to insure a positive drive, especially under load. The new routing (TSB #07-001-06) leaves the alternator and power steering pump with less than 180 degree belt engagement.
I don't know if this is a potential problem.
Thanks.
Old 03-09-2006, 05:43 PM   #9
Luck881
I'd just like to bump this back for a bit. I can't believe I'm the only person that's had this problem since there's actually a TSB out addressing the issue...
Ian
Old 03-09-2006, 06:16 PM   #10
R.T.
You're not alone. I have a 2006 with the 2.4l and have the same problem. The dealer had to order the new belt. I am waiting for it to come in now. In fact, this reminds me to call them. Thanks
R.T.
Many men can do what others cannot, and most of it is useless - John F. Gilbey
2006 TJ SE, Flame Red, Black Soft Top, 1/2 Doors, 6 speed manual trans, BFG ATs & Rock Crawler Black Steelies.
Red Jeep Club Member #389
R.T. is offline   Reply With Quote
Old 03-09-2006, 08:59 PM   #11
terrible
terrible's Avatar
Mine squeaks a bit when it is moist outside as well. I'll have to check into this, thanks.
terrible is offline   Reply With Quote
Old 03-10-2006, 04:07 PM   #12
ribsyj
I have prob with my 05 but when i just rest my foot on the clutch it stops i did not take mine back yet but it is not the belt for sure so if yours is a stick try resting a little on the clutch to see if it stops cuz mine does
87 wrangler SOA 4" skyjacker springs dana 60 gm 14 bolt AMC 304 dana 300 and 39.5 Iroks
05 Tj 3" 32" MTs
88 F-350 Tow Rig
[url]http://www.cardomain.com/id/ribsyj[/url]
ribsyj is offline   Reply With Quote
Old 03-10-2006, 07:07 PM   #13
DeepC
My 03 SE had this problem for about the first 6 months after I puchased it. I had brought it to the dealer atleast 6 times. They dressed the belt twice then ended up replacing the belt later. After some more time they replaced the tensioning pulley and it went away. I havent had any problems since then but I did see the TSB out for it. If it starts up again I'll just get the new belt and take out the pulley as per the TSB since my warranty is now done.
DeepC is offline   Reply With Quote
Old 03-11-2006, 03:32 PM   #14
Luck881
Just back from the dealer and everything's cool. they swapped out the belt and removed the center idler and my squeak is finally gone. If anyone else gets a mysterious squeak from a 2.4, the serpentine belt is the problem. The TSb adresses the problem perfectly.
Ian
Old 03-12-2006, 02:04 AM   #15
ribsyj
do any of you have a lift if so what does the dealer say
05 Tj 3" 32" MTs
88 F-350 Tow Rig
Glock Forum
