Quantcast trying to pain tgalvanized shcakles. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > trying to pain tgalvanized shcakles.
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 08-04-2005, 10:23 AM   #1
kaybone
Hmm, these shackles are becoming a magilla. Im trying to paint my galvinized shackles so I cleaned them off real good with dawn soap and primed them with regular old auto primer after they where dry and now the primer seems to be flaking right off. Well I can't paint over that so I'll strip off the paint with chemical stripper and start again. So whatya think coat them with a metal etcher like"metal ready" or something like that and then paint color? Any suggestions?
Gun Metal Blue Jeep Club Member #99
kaybone is offline   Reply With Quote
Old 08-04-2005, 10:37 AM   #2
jkulbeth
I've not tried it, but I've heard that paint will adhere better to a galvanized surface if you wipe it down with vinegar.
2004 Wrangler Unlimited, Shale Green, soft-top, Shrockwork Rocker Guards, Kumho 31x10.5 AT's
[COLOR=DarkGreen]Green Jeep Club Member #119[/COLOR]
jkulbeth is offline   Reply With Quote
Old 08-04-2005, 10:43 AM   #3
PaJeep4x4
I have some old Warn D-rings that were galvanized finished, and wanted to snaz them up a little. I didnt prime them at all, as primer only sticks to bare metal. I used a can of red Krylon. 2 coats later they were awesome , even when I throw them around in my recovery/tool bag. Give 'er a try.
PaJeep4x4 is offline   Reply With Quote
Old 08-04-2005, 10:53 AM   #4
djab
black Krylon used on mine. no primer and they've held up and look great
djab is offline   Reply With Quote
Old 08-04-2005, 11:29 AM   #5
Dogman
Krylon Fusion is the easiest paint I've ever worked with. I'll give that a try when I pick up some D rings. By the way, what size should I get? I've got a rock-it man bumper if that matters.
Dogman is offline   Reply With Quote
Old 08-04-2005, 11:37 AM   #6
RockRunner85
If you use those for recovery the paint is going to come off from the strap at somepoint. It'll just make a mess on the strap and the shackle will look worse half painted half not. Just my 2 cents. I did paint the pins as mine were orange and it kept coming off on my hands. However the paint is coming off that as well.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 08-05-2005, 07:54 AM   #7
kaybone
Ok, so I stripped the flakey primer off with a chemical stripper, treated them with POR15's "metal ready", washed them down again with soap and water then painted with rustoleum. Works fine now. thanks everyone!
Glock Forum
