TRYING to install lift, poly isolator will not fit - JeepForum.com
post #1 of 39 Old 07-27-2010, 10:29 PM Thread Starter
HDHD
We're in the middle of trying to install a RC 3 1/4" lift, when we came to the step of replacing the front spring it said to add the poly isolator spacer, but the spacer will not fit. The lip is getting caught and it will not go up any farther. what do we need to do?
HDHD is offline
post #2 of 39 Old 07-27-2010, 10:31 PM
AFjeepMan
did you remove the factory bump stop cup? if so try using a little WD-40 to help it slide? My 3/4" spacer went on with no problem
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 39 Old 07-27-2010, 10:40 PM Thread Starter
HDHD
How do you remove the factory bump stop sups?
HDHD is offline
post #4 of 39 Old 07-27-2010, 10:41 PM
Crockett
remove the rubber bumb stop and use a 15mm socket and take the cup thing off and it will slide right on
Crockett is offline
post #5 of 39 Old 07-27-2010, 10:48 PM
AFjeepMan
you may need to use channel locks to grab onto the rubber bump stop to work it out, and remember, pb blaster is your friend!
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #6 of 39 Old 07-27-2010, 10:49 PM Thread Starter
HDHD
OK thanks... got the bump stop off, but does the factory poly isolator need to come off also?
HDHD is offline
post #7 of 39 Old 07-27-2010, 10:51 PM Thread Starter
HDHD
I've been trying to get my husband to use PB but he is fighting me on it... It has worked on all the places we've used it on already.
HDHD is offline
post #8 of 39 Old 07-27-2010, 10:54 PM
Crockett
i just did one of these lifts and i left the factory isolator on and it really made it look level.
Crockett is offline
post #9 of 39 Old 07-27-2010, 10:57 PM
AFjeepMan
you can either leave it in its stock position, or you can do what I did, and put the poly spacer above the isolator, the isolator will slide off with a little bit of convincing from mr flathead screwdriver...its a better look in my opinion and it gives you the same outcome. PB Blaster is magic in a can and that is all I have to say!
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #10 of 39 Old 07-28-2010, 12:44 AM Thread Starter
HDHD
I love how the instructions say installation time 4-6 hours. I'm taking it that it means 4-6 hours to complete not 4 hours on just the drivers front side! Oh well I guess we'll start the other side tomorrow. Thanks everyone for the help... I'm sure I'll need some more the deeper we get into it!
HDHD is offline
post #11 of 39 Old 07-28-2010, 01:14 AM
inglisleslie
BFH it!
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #12 of 39 Old 07-28-2010, 01:20 AM
inglisleslie
or cut it off and replace...some jeeps are old and grumpy
/l ,[ ______],
()_) ()_)--O-)_)
post #13 of 39 Old 07-28-2010, 06:39 PM Thread Starter
HDHD
So should I be worried that the passengers side front sway bar was broken off before we started the lift? Could this be the reason why that tire was rubbing when I would turn the wheel all the way on that side?
HDHD is offline
post #14 of 39 Old 07-28-2010, 07:02 PM
cheapjeep06
Killeen, huh? I used to live at 3800 Sunflower Drive after I got out of the Army. Before that I lived in Copperas Cove behind Wal Mart.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #15 of 39 Old 07-28-2010, 09:47 PM
AFjeepMan
where was the sway bar broken? pictures? what size tires did you have and were they stock wheels?
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
rc , lift , rough country lift
Poly Performance LA Kit Install Niceface JK Wrangler Technical Forum 3 04-10-2010 10:02 PM
Poly Perf. Tie Rod Install Questions DeepSky JK Wrangler Technical Forum 7 09-28-2009 08:08 PM
Poly Body Lift jeep2008 TJ Wrangler Technical Forum 9 10-26-2008 01:40 PM
Poly tranny mounty install... c_gilbert TJ Wrangler Technical Forum 6 04-12-2006 03:50 PM
NE1 install a poly trannie mount? KnightFire TJ Wrangler Technical Forum 2 09-11-2002 09:24 PM
