Trying to fix stripped caliper bolt hole - JeepForum.com
 1Likes
  • 1 Post By mrblaine
post #1 of 5 Old 09-23-2017, 04:24 PM Thread Starter
Jwolfer
I am working on fixing my front driver side caliper bolt hole that was stripped. I bought all of the pieces of the black magic knuckle saver kit locally because I need to knock it out this weekend. I drilled out the bad hole with a 27/64 drill bit and then tapped it to 1/2"-13 but the M8x1.25 threaded inserts are too small for the hole I tapped. Any advice or am I going to have to replace this whole damn knuckle since I've already drilled it?
Jwolfer is offline
post #2 of 5 Old 09-23-2017, 04:28 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
@mrblaine will likely be able to help you figure out what happened or what you need to do.
Jerry Bransford is online now
post #3 of 5 Old 09-23-2017, 04:35 PM Thread Starter
Jwolfer
Let's hope so. The knuckle is going to be a PITA to swap out.
Jwolfer is offline
post #4 of 5 Old 09-23-2017, 04:37 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You likely bought a helical insert or a wrapped wire insert. The insert we sell is EZ Lok and the 8mm with the 1/2-13 external threads falls into their heavy wall category. They are solid inserts that are machined with internal and external threads.
Here is the part number so you can try to locate them online.
They are designed for through holes and the helical wire versions are best in blind holes.
https://www.ezlok.com/cds_catalog_product.php?id=650_8
Shark_13 likes this.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #5 of 5 Old 09-23-2017, 04:47 PM Thread Starter
Jwolfer
Ok awesome. Thanks for the great info as always!
Jwolfer is offline
